I have a samsung syncmaster flatscreen monitor which was working fine one minute, then when i went out the room and came back 5 mins later, the screen was blank and i couldn't seem to get it to display anymore. The pc was still running. The power light on the monitor was flashing (it does this on standby when pc is switched off but monitor is on). I disconnected the monitor from the pc and a little box appeared on the screen saying "searching for signal" or something like that. This message disappeared when i reconnected the monitor to the pc. Obviously without being able to see what i'm doing i couldn't shut down the pc properly and so had to switch off via the mains. Now when i switch the mains on the pc starts running automatically but still will not display..... HELP PLEASE? Does this sound like a monitor problem or a pc problem? Thanks
  • danf76 May 29, 2008
    Hi, thanks but i'm not sure what you mean by the video jack connector? Do you mean the lead connecting my monitor to my pc? I have no jack leads coming from my pc.
    The only other thing i can think of is that my wireless mouse and keyboard have failed for some reason and therefore i can't get out of powersave?
    Problem Solver:
  • 8 Answers
Check your video jack connector have it replace
Posted on May 28, 2008
Samsung SyncMaster 2333hd monitor shuts on and off repeatedly or turns off
I had a similar problem with my monitor, it turned out to be a loose connection inside the unit, there is a motherboard inside the monitor, it was between this and the LCD that a cable had come loose, some dismantling of the monitor but worth a try.
Mar 04, 2014 | Samsung SyncMaster Computers & Internet
Samsung T240 Problem
try check the cables and connection
Dec 17, 2013 | Samsung SyncMaster T240 Monitor
Fuzzy/blury fonts on a samsung syncmaster 920nm
Good morning! Please review/check the set-up settings of your samsung flatscreen, best to refer it to the operations manual of the monitor which should be included when you bought it. best regards.
May 02, 2009 | Samsung SyncMaster 920NW Monitor
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Monitor 720N
check the resolution of the system make it as 600*800.
Jan 06, 2009 | Samsung SyncMaster 720N Monitor
After few minutes I have disturbance in picture on SM T200
i have almost the same problem and can't find a solution... hopefully the guy who made my computer know whats wrong with it...
my samsung syncmaster is also connected to the DVi port(digital)
and it's sometimes working for a day and other times for a minute of 5.
and now i get it always in games what i get is:
-screen go black and in the top left corner yuo see analog(VGA port)and then digital(DVI) again.
and this will continue for at least 5 min sometime it stops after that sometimes never and i need to reboot(1of 5 times that work sadly)
-i get a buzz sound while he is doing that.
-sometime i get a green flash in the shape of what i was doing and then he change again.
can anyone help me/us?
Dec 20, 2008 | Samsung SyncMaster T200 LCD Monitor
Samsung 15' sync master monitor
Hi...there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it...
Dec 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
SAMSUNG SYNCMASTER 191T PLUS
I have the same problem. Have you found a solution?
Aug 24, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
