Question about Vulcan Kitchen Appliances - Others
I need a wiring diagram for a vulcan lg 400 fryer
4 Suggested Answers
burzerko
  • 254 Answers
SOURCE: Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
Posted on Jul 24, 2008
SOURCE: need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
Posted on May 12, 2009
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Posted on Dec 18, 2010
Where is the reset button on vulcan fryer?
Most Vulcan fryers do not have a reset button. The high limit is self resetting when the fryer cools down to a safe temperature.
May 31, 2014 | Vulcan Fryer LG500-NAT
If wires are crossed will burner work
It depends on which wires are crossed. Switching the wires on a two wire high limit, thermostat, or thermopile will not matter. The wiring on the gas valve must be correct for the fryer to work properly and safely.
May 29, 2014 | Vulcan Kitchen Appliances - Others
My vulcan lg 300 deep fryer latch won't turn what should I do
Some fryer valves have a safety lock, usually a slide on the handle near the valve body that must be released to open the valve. Check for this first. It's very rare for a fryer valve to stick unless it was forced shut with something partially blocking it. If not, let the fryer cool completely. Dip as much oil out as possible. Then disconnect the gas line and, with help, turn the fryer upside down draining the remaining oil into a suitable container. At this point, you have little to lose. Take a large wrench or piece of pipe to get more leverage and try to force it open and free it up. Do not use so much force that you damage the kettle. If you get it free, check to see that it does not leak before putting oil back in the fryer. If it leaks or fails to come free, replace the valve.
May 23, 2014 | Vulcan Kitchen Appliances - Others
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
Pilot wont lit
The first thing to do is make sure all the air has been purged from the gas line.
Oct 12, 2013 | Vulcan GR45 Deep Fryer
I cant buy just the nat gas to lp gas conversion parts for a Vulc
call your gas supplier as they have reasonable sources for all of these parts. shame on vulcan.
Mar 31, 2009 | Vulcan EF3 Deep Fryer
Vulcan Deep Fryer, burners shut off, remains off!
sounds like your gas valve to me, you need a manometer to test it under gas pressure.
Dec 07, 2008 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
95 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
