Question about Maytag Neptune MDE9800A Electric Dryer
My Maytag Neptune model MD9800AYQ electric dryer stopped working. It doesnt turn on, no LCD display. I've confirmed the breaker is fine and the inside light works. Any suggestions?
  • jazz_man1962 Oct 07, 2010
    Original question:
    1st Response (which didnt correct the problem was: It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel.
    I REPLACED BOTH THE THERMAL FUSE AND THE THERMAL CUT-OFF FUSE, AND I STILL HAVE NO POWER TO THE LCD. ANY OTHER SUGGESTIONS? ps. I DONT KNOW THE 1ST THING ABOUT AN OHM METER NOR DO I HAVE ONE.
  • 10,865 Answers
Hello Jazz,
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Joe.
Posted on Oct 07, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 05, 2010
Control Panel Doesnt Light. Breaker is good. Interior bottom light works ?
possible bad connection to the cord, inside the dryer.. unplug it, remove the rear panel, and do a continuity check with a meter.
Mar 11, 2014 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
Mde6800ayw dryer just stopped working
Have her turn the breaker off to the dryer,then back on.
If it is not a incoming power issue the part #21 in the diagram will need replacing.
The connecting vent will also have to be checked for obstruction of airflow.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174651
cut and paste this link and find the thermal fuse part #21.
Jul 25, 2010 | Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our maytag Neptune Dryer is showing 8.8 on the display. It has done this in the past and we have had it looked at and they could fine nothing wrong. Now it doesnt work again.
usually thats indicitive of a powerfailure
try unplugging the unit for several minutes
your trying to clear the e-prom
if you cannot clear it that way
more than likely you will neeed a new control
Oct 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Apr 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune MDE9800A Electric Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
