Question about Neff U1452 Double circotherm plus Electric Oven
Any idea how much a new element for Neff U1452 will cost?
  • Neff Master
  • 3,463 Answers
Depends on whether you purchase a genuine element or a copy one.
You could get a copy one for under £10.00, or pay as much as £30.00 for a genuine element.
Posted on Oct 05, 2010
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
Neff u1452 element cable has dropped down the back
call chas&son,s at 570-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | Neff U1452 Double circotherm plus Electric...
How to remove main oven door on neff u1564
Use link
http://www.neffcustomerservice.co.uk/
click on instruction manual download (bottom left of page) this will open new window, enter U1452 in search box... click on first result and go to page 36 of downloaded PDF this will give you the instructions.
All the best, hope this helps
Aug 30, 2011 | Neff U1452 Double circotherm plus Electric...
My U1452 has recently been tripping electrics, and after the latest time the oven has not been heating up! Is this the fan or something else?
If the fan is working o/k, then you need to replace the oven element located at rear of oven compartment behind a removeable cover.
Oct 05, 2010 | Neff U1452 Double circotherm plus Electric...
My fan oven element( Neff U1452 )has been replaced
they should last 12 months minimum there could be a problem with your fan motor here is a standard fan oven check list.
You-Tube video "6QGurNvbI0Q" placeholder (do not delete)
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff U1452 Double circotherm plus Electric...
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Oven temperature
element is open circuit. part easilly available and easy to fit
Mar 16, 2007 | Neff U1452 Double circotherm plus Electric...
Neff U1452 Double circotherm plus Electric Oven Logo
203 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
