Question about Vizio VX37L Television
Vizio VX37L. Power on turns logo on front panel white but nothing else happens. Have to unplug to turn off. Checked PS fuse and it has continuity. Checked 5, 12 and 24V output pins on PS and it checks to correct voltage. I have unplugged it and held the power button for 1 min. and unplugged it for over an hour with no results. Can you help isolate the problem better?
  • 10,594 Answers
Hi.
We here at FixYa hope that our esteemed colleague could completely satisfy your current inquiry.
If your issue has not yet been rectified, I will be glad to assist you further.
Should you desire any assistance, please reply to this message and Thanks for choosing FixYa.
Posted on Oct 06, 2010
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
Vizio vx37l hdtv10a
If recently bought, take it back as a default.good luck..
Dec 07, 2013 | Televison & Video
HAVE AVX37LHDTV10A NO PICTURE NO SOUND NO BACKLITE LIT
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
I have a Vizio VX37l and was watching it and then I heard a pop and the tv went black. The power light still is on on the Vizio on the front. I checked the fuse inside and it was fine.
It sounds like the 5vdc standby circuit is still working, that is why the main fuse is still good but you may have bad 24vdc power supply, look real close again for blown transistors or IC on the power supply board, but it can also be the backlight inverter circuit boards that blew up also. Look here to see what good parts look like: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX37L+
Please post back what you find.
Dec 08, 2009 | Vizio VX37L Television
Vizio has no power want to check fuse
remove back, only exposed board there is PS, look where blue/brown AC wire plugs into it, fuse (F1) is there (5amp-250v)
if fuse is good and you get no power or front light replace that board, or start component level troubleshooting (usually regulator trans or SM fuses (000)
Jun 24, 2009 | Vizio VX37L Television
Vizio VX37L Television Logo
368 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
