Question about Neff 3.2 cu. ft. / 91 liter Upright Freezer G5624
I have an old lec freezer which seems to work okay although we get moisture on the outside of the appliance..
  • 4,793 Answers
The moisture is just condensation from the room its in,(same as tiles in bathroom.)...cold surface warm air.
Posted on Oct 05, 2010
Red light on lec freezer keeps on but not freezing
Seems like the compressor on the freezer stopped working
Jun 27, 2016 | LEC Freezers
The outside front of the freezer case gets hot.
It's normal to touch it hot on the outside front.
Because it has heater to keep moisture out in the body metal of the freezer.
Those moisture if not heated to dry, can cause rust build up.
Rust build up can destroy the metal body of the freezer.
Thanks for asking.
Jun 29, 2011 | Woods Chest Freezer C1501W3
Upright Frigidaire Freezer, Model#: MFU14F3GW9 It's approximately a 7-9 year old upright freezer. I believe the door may have been left cracked for an extended period of time, but I'm not positive....
if the doors shut okay,and there is no frost,and it is maintaining a steady internal temp(-18C to -20C) why worry.......anything else is going to cost money.......
Apr 05, 2010 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
New freezer from Sears, seems to be working okay, but the top and sides are very hot to the touch. I wouldn't think this is normal operation.
I don't know what brand or model of freezer you have but all of them have inside their walls a pipe with hot gas (freon under pressure from the compresor) or a heater to keep the outside free of moisture ,but if it's very hot it could be that the coil is dirty or something is blocking the air vent.
Aug 15, 2009 | Freezers
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Neff 3.2 cu. ft. / 91 liter Upright Freezer G5624 Logo
162 people viewed this question
Top Neff Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Neff Freezer Expert? Answer questions, earn points and help others
