Question about Gateway FPD2275W LCD Monitor
Computer Moniter screen turned purple
Hi! My computer moniter's screen turned purple. My moniter is a CRT. I have a branded HCL pc
    Genius:
  • 1,011 Answers
This is a problem with the video cards hardware or the driver itself depending on your card you should updaate your cards driver from the appropriate site,right click the desktop>properties>settings>advanced>ada... will then see the name and manufacturer of your graphic card
go to the appropriate website and download the latest driver,here are the three main graphic card manufacturers websites
1) nvidia.....http://www.nvidia.com/Download/index.asp...
2)a.t.i.....http://ati.amd.com/support/driver.html
3)intel...http://support.intel.com/
other things to check are
1.make sure your graphic card is securely fitted and if power is required to the card,then check the power connector is securly fitted and inserted
2.try changing your monitors lead from the v.g.a connector to the d.v.i connector at the back of the card,the v.g.a. is a blue connector and the d.v.i. is a white connector,and the d.v.i requires a d.v.i to v.g.a converter
3.where applicable install any monitor drivers however these are rarely required
4.run the direct x diagnostic utility,press start>run>type dxdiag >press enter,then go to the display tab and run the "test direct 3d" test
5.finally check all cables are securly fitted
if after these tests and tasks you still experience problems then change the graphics card and run the tests again,if you experience more problems then a new video/graphic card is required
any problems let me know
good luck .......
"Don't forget to rate the solution"
Posted on May 28, 2008
Hcl moniter screen adjust problem
hi. this may be from EEPROM IC. you can program it or replace IC with new one and then program it.
Apr 27, 2015 | Computers & Internet
Moniter power light blinks purple.
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Smart Modular SV3170A
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
Demagnetize computer monitor
It looks more with screen resolution problem, if it is new then the best option is get it replaced.
Dec 12, 2007 | HP mx705 17" CRT Monitor
BLANK SCREEN
screen goes dark I tried the moniter in a different pc with the same result. i think there might be problem in monitor adjustment. 2 if it is ok then the problem in video section. 3 also check for loose connector 4 crt base might be loose.
Sep 26, 2007 | Dell E773C 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
