Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
I have the HP Officejet 6500 printer/scanner/fax/copy. I have set it up with the USB cable (not wireless), and now every time I try and scan, it tells me: "No scan options." Help!
  • HP Master
  • 5,380 Answers
Did you install the full featured software or did you connect the printer to the computer and get a generic driver? The generic driver in the OS may not control the scanner on an all-in-one. Remove any generic driver and unplug the data cable. Download and install the software from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3795406& , select your OS.
Check through HP update if there is a patch to your driver or software. If you use a USB hub or print server, try a direct connection.
Are you launching the scan from the printer or from the computer? You need the monitor program running and to have set the scan destinations in the HP software before using the buttons on the unit. Try launching the HP software and scanning there. Once you do that you will have a better idea of the destinations and default settings to use in the Scan buttons on the software. These will be uploaded to the printer by the software.
I hope this helps.
(Scanners require bi-directional communication with the computer so try a new data cable if problems persist.)
Posted on Oct 05, 2010
Are you running Windows 7 on your PC? This is a relatively common problem with this printer and Windows 7...
The fix from HP is to reinstall Windows 7... Yes. That is ridiculous.
HP considers this to be a windows problem and not a printer problem.
If you're running an OS other than Win 7 try reinstalling the drivers. You can find them here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&os=228&product=3795406
Jan 07, 2011 | HP Officejet 6500 Wireless All-in-One...
The HP Officejet 6500 will now only print color copies, the black copies do not print, the officejet does not recognize the request to scan copies, the officejet will send faxes and show a fax is being...
not ridiculous as the new printer costs less than replacement cartridges
check for ink in the black cartridge
check that the driver is still connected
check for compatibility with the pc
Jun 04, 2017 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 709n will not Scan - Please email me at address below: ronaldbartholomew@yahoo.com
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Says scanner failure, scan, copy and fax will not work, did the print alignment still not working Only the printer works
try use a high quality usb cable, some usb cables has low bandwith, and give some strange, errors like scanner error, copy,...
Feb 09, 2010 | HP Officejet J5780 All-In-One InkJet...
The fax auto answer goes off when the 65oo is in
You could try these two suggestions from HP support. The semi-full reset will affect quite a few settings. Perhaps you should copy down these settings for reference later.
HP OfficeJet 6500 Auto Answer
Jan 08, 2010 | HP Officejet 6500 Wireless All-in-One...
On sending a fax the receiver copy has a black
You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
237 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
