Question about Ovens
DOES THIS COOKER NEED WIRERING IN OR DOES IT HAVE A 3 PIN PLUG
  • 4 Answers
Backing number
Posted on Oct 05, 2010
Does it need 6mm hard wired cable or can it be used with standard 13amp plug via ring min
hard wired is the normal way ranges are done unless they are gas .then the electric can be lighter gauge
Apr 23, 2016 | Ovens
I BUY FROM ARGOS A BUSH COOKER THEY DELIVERY TO MY 3 FAULT BUSH COOKER.I'M STILL WITH A FAULT COOKER
call them and tell them what the problem is . we have no idea where you got or what you got
Jan 26, 2016 | Ovens
How to connect a electric cooker
It would have been helpful if you had provide the make and model of your oven/ cooker. If it is an electric cooker you will have to contact an electrician to provide the power connection and connect it. But if you already have a mains power connector at the spot where you want to locate the cooker and the cooker has a compatible power chord connector then you can simply plug it in and start.
If there is anything specific you want to find out about this then please type the question in the comment section. We cannot provide further information without knowing the make and model of the appliance.
Aug 14, 2014 | Ovens
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
