Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 front loader
The cleaning cycle has finished but the rinse water has not drained yet. can you help. thanks
  • helitrek Oct 04, 2008
    Will not drain, pump not blocked or clogged, 3 beeps when switched on
  • Anonymous Oct 29, 2008
    i have a maytag neptune front load washer and the problem is the washer
    spins but do not rinse and do not drain
I have a zanussi washer it is reading error 92, what does this mean? Thanks!
Posted on Aug 06, 2008
    President:
  • 1,294 Answers
If the filter is clean & the water does not drain, check your pump for any clogging.
Posted on Jun 16, 2008
    Problem Solver:
  • 4 Answers
Check the filter down on the right and cleane it
Posted on Jun 04, 2008
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Jun 08, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Zanussi zwf 1440
Something wrong with the pump,leave out let hose down as flat as possable into a basin or whatever,to drain water,remove pump test and check it.
Sep 05, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi ZWF 1432 washing machine
because theres more water it takes a lot longer to heat.
May 04, 2008 | Zanussi ZWF1430W Front Load Washer
WASHING MACHINE FRONT LOADER
If it's similiar to the F1231 w than i found a color catcher caught between the pump impeller and pump cover. this is located at the bottom right front of the 1235W and flips open. grey hose beside it pulls out and remove cap of hose and drain into bowl.
Tip take wet clothes out of machine to speed up the emptying of machine - this dawnwd on me after a few minutes.
Some more water will come out when you remove the pump cover - screw anti clock wise.
ee pages 18-19 of the zanussi guide for cleaning instructions. I found this link to manual on internet
http://www.manualshark.org/manualshark/files/6/pdf_13638.pdf
or check your own manual for cleaning instructions and remember unplug power first - just in case. you may need to reset your wash to do a rinse again as i got a vibrating sound when i restarted and skipped to spin. hope this helps
Dec 31, 2007 | Zanussi Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
422 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
