Question about Pyle PL71HRBK Car Monitor
Can you connect any version of the Flip Camera and play it back through a Pyle Monitor? If so how do you do it? Do any of the Pyle monitors come with a direct usb connection?
  • 1 more comment
  • eric846 Oct 05, 2010
    thanks for the response. I'm very familiar with how the Flip Video Camera works...what I need help with is specific to which PYLE Monitor the flip camera is compatible with? Further do any Pyle Monitors come with a direct USB Connection?
    Please respond to my last comment
    I would like to know what Pyle Monitors are compatible with a Flip Video Camera?
    Can any pyle monitor handle direct USB connection to play back Flip Video on larger screen?
    If not pyle monitor than what monitor is compatible with Flip Video? What connection would be required to play Flip video on larger monitor?
  • 857 Answers
Yes you can do that,
Follow these steps :
•Connect your camera to the VGA converter box via an RCA video cable. Plug one end of the cable into the yellow composite RCA port on the converter box and plug the opposite end of the cable into the yellow composite video port on the camera.
•2
Connect the converter box to your computer monitor via the box's VGA port. For CRT monitors, plug the monitor's built in VGA cable into the VGA port on the converter box.
•3
Use a VGA-to-VGA cable to connect an LCD monitor to the converter box. Run the VGA cable from the VGA port on the converter box to the VGA port on the back of the LCD monitor.
•4
Use the three-mode resolution switch on the side of the converter box to set the video quality and resolution of the converted signal--your monitor will likely support all three resolution modes.
•5
Plug the tip of converter box's power adapter into the red DC power port on the converter box--plug the transformer end of the cable into a power outlet. Power on the camera, the VGA converter box and your monitor.
Yes they do come with the diret usb connection as well.
Posted on Oct 05, 2010
  • Jayant Jha Oct 06, 2010
    Usb connection will work.
    •1
    Locate the USB output on your camera. On some models it is near the front, right next to the lens, while on other models it is on the back or in the control cavity underneath the LCD screen. Consult your particular model's owner's manual for the exact location.
    •2
    Connect the camera's USB output to to your computer's USB port via a USB cable. Most modern computers come with multiple USB ports, and they are typically located on the side on laptops and on the front or back on desktop towers.
    •3
    Power on your camera and flip out the LCD screen. You should be presented with the option "Playback Files on Computer" or something very similar.
    •4
    Select the "Playback Files on Computer" option. This should prompt a menu to pop up on your computer asking what you'd like to do.
    •5
    Click the "Open Folder to View Files" to access your camera's hard drive. You can now drag and drop the clips you want from your camera to your computer for storage and editing.
    Brigadier General:
  • 3,513 Answers
Please check the links bellow if it helps:-
http://www.ehow.com/about_5048214_flip-camera.html
http://www.ehow.com/how_5832401_download-flip-video.html
http://www.ehow.com/how_5969609_do-flip-video-clips-website_.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
  • Aparajita Batabyal
    Aparajita Batabyal Oct 05, 2010
    yes pyle monitors do come with usb connections,here is a link bellow you can check,,,
    http://www.amazon.com/PYLE-PLMN9SD-9-Inc...
    Thanks
I have just install a rear view camera and monitor,it comes on when i put car in reverse but as soon as i touch the foot brake the monitor shuts of,why does it do this?
It sounds like you connected to the conductor (wire) that controls the actuator that locks out shifting the transmission which is then disabled when you actuate the brake.
Please provide the model of the car and video system; I may be able to get an electrical schematic and trace out the signals.
Nov 02, 2014 | Pyle Flush Mount Rear View Camera w 0 Lux...
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
Pyle PLCM4300WIR
The Green wire is a reverse trigger wire. It should be tied into the reverse light hot wire. This tells the monitor to turn on and switch to Video 2 so that it displays what is seen by the backup camera. When you take the vehicle out of reverse thus removing power from the green wire, the monitor switches back to normal driving mode. ( no video displayed ).
Jan 15, 2012 | Pyle Car Audio & Video
Pyle plcm7300bt what does the green wire reverse car wire connect to + or ground
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
Jan 09, 2012 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
Jun 24, 2011 | Pyle PLCM7200 Car Monitor
There is a black power cable with two leads for the power for the camera but I don't have in the instructions what to do with it
This is how to hook up the Pyle PLCM7300BT:
On the license plate camera, plug the black cable provided with 2-wires inside (one red and one black) to its counterpart on the camera. On the open end of this black cable, strip and connect the black wire to the car/truck metal body part.
Connect the red wire from the camera and the green wire from the monitor (part of the big black cable from the monitor) to the power wire to the back-up lamp socket.
Connect the Red wire from the monitor to a switched terminal on the fuse box so that it would only have power when you have the ignition key on.
The rest of the wiring is simple and common sense.
To operate, turn on the ignition of you car/truck and put it on reverse you should see the camera view. Put the car/truck on Park, the monitor screen should go back, if not, push the power button once.
To set up the blue tooth: Push the power button on the monitor so that you can see the blue screen and "no Input". Put your phone on discoverable mode and push scan for device. AT the same time push the "pair" button on the monitor.
I did all the figuring out on the bench using a 12 VDC power supplies and contact switches to make sure I understood how it worked. Once installed on my 1988 Suburban, it worked as expected.
The only problem I had to patch the long green wire (reverse car) so that it reached the back-up light socket.
Let me know if you still have problems. Email me at wayne.tan@wdc.com
Wayne Tan
Feb 24, 2011 | Pyle PLCM7300BT Mirror Monitor
Can you provide some install steps to the pyle view plcm7300bt?
only step that is missing is the red wire one the camera.Use the adapter that is in the kit and attach it to your back-up lights this is used for your night LED's
Dec 20, 2010 | Pyle PLCM7300BT Mirror Monitor
Flip HD camera frozen "on"
Just take out the batteries and put them back in. That should fix your problem. =)
Dec 06, 2009 | Pure Digital Flip Video Ultra Camcorder
Game Graphics suddenly Scramble
Try another monitor to see if the same problem happens.
Jun 04, 2008 | ViewSonic VX2235wm LCD Monitor
Pyle PL71HRBK Car Monitor Logo
82 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
