Ricoh 1515MF Destination List Update failure. I configured this machine years ago to scan to a network folder. PM last week wiped its settings and I cannot figure out I did it.
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
  • 54 Answers
SOURCE: Unable to "Scan to PC" for anybody else, but me!
The Save number and the Registration Number must match, folder # will be same as save and registration number.
Posted on Jul 09, 2008
  • 6 Answers
SOURCE: Konica Minolta Bizhub Copier/Printer How to Scan
download the ip scanner, then install it, u should be able to scan from there, is a straight forward program, need to unblock this ip scanner in ur windows firewall.
Posted on Aug 09, 2008
SOURCE: Scanning - error: Sender's name not selected
Finally figured this out!!
Go to: UserTools - System Settings - File Transfer Tab - page 3 of 3 - Auto-Specify Sender Name - <ON>
Posted on Jan 28, 2009
Scan and Send not sending - CAnon Image runner Advance 5045 - was working 3 weeks ago - not working now
working 3 weeks ago. well, something must have changed in your network since then, check smtp server with your mail provider if it is scan to email. if it is scan to the file, check firewall, ip addresses, destination folder, login and passowrd to the destination pc.
Jul 31, 2013 | Canon imageRUNNER 5000 Copier
Destination list cannot be used now ricoh aficio c2800
If you are using an LDAP server to provide the destination, you may not have the Search Conditions programmed correctly.
Feb 27, 2012 | Ricoh Aficio 1515MF All-In-One Laser...
I can't set up scenner options in aficio mp2000
look here in Ricoh white papers you should be able to find what you need. http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Mar 16, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
My mp 2000 ricoh scanner and printer only works for printing, not for scanning
if you have not set it up to scan you need to do so. go to ricoh.com then americas then knowledge base then white papers. and look for how to set up scanning to email or to folder.
Jan 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Device does not recognize delivery server
this device does not support scan router v2 lite.
your best bet would be to set up using SMB scan to folder.
set up is pretty straight forward create a folder on the root of C: ie C:scans
share the folder with full permissions, simple file sharing has to be turned off!!
then go into the device web page using the IP address ie: 192.168.xxx.xxx.
go to configuration and smb create a user name ie: bill then point the device to the computer you created the folder on, ie: bill's pc/c:scans
save the configuration log out of the web utility reboot the device and you should have succesfully created an smb folder share.
if this resolves or answers your query please rate me accordingly
good luck and thanks
Aug 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How to configure scan to folder?
new models of Ricoh is having same procedures to do scan to folder. You had to make sure first that the destination folder on the pc is shared with full permission to everyone or on a specific username. Then on the machine you had to specified the folder path and the proper authentication. Then you can do scan to folder. "Sometimes the pc automatically shutsdown or scan doesnt goes to the folder due to the antivirus which your using".
Apr 13, 2009 | Office Equipment & Supplies
"Updating the destination list has failed" Error message on Savin
It is a communication problem that's all.
I may or may not be able to help.
Are you using a scanning software on your server to scan to folders? for example "Scanrouter V2"? -you can check on your server in "start" , "programs", you will see it there if it's installed.
If so do this:
open "Scanrouter V2 admin utility"(you should just have to click 'OK' when asked for password -it's usually not set) then and under the "server" button select "set I/O device", then select "remove". If you are asked to "retain settings" select "no". Then add it again> click "add", then "Browse", it should find the machine (either host name or IP address), select "ok" then name it whatever you want - it's for identification only. Destinations should re-appear if you Update.
If you scan via SMB, Email or otherwise, you'll have to get your IT dept, or whoever configured in the firstplace to figure it out.
*please rate response :)
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Ricoh 1515MF Scanning
Easier said than done...you'll probably need a tech for this one.
First..to scan to folder you require a software called "scanrouter Lite" from Ricoh, which is actually kind of hard to get a hold of these days, since it's nnot supported anymore, and then the configuration is not easy , because it is proprietary...meaning only Ricoh uses it, and it is almost impossible to configure for anyone else that has not used it.
There is however Scan to email, and for this you can open a web browser, and type it's Ip address (if you have it connected via tcp/ip port), enter "admin mode"...user name= "admin", password = "password"...then enter all network settings...IP, DNS, POP,SMTP, etc. then in "address book" enter your destination settings.
This is not a configuration that is easy for a novice either, and it is also not compatible with an email server that uses authentication for outgoing mail.
I may not have helped, b ut I hope I clarified.
Feb 26, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
k24674
