Question about Echo Back Pack Blower Pipe Kit Pb4600 Pb6000 + More
INSTALLED NEW CARBURETOR NOW WILL NOT START? - Echo Back Pack Blower Pipe Kit Pb4600 Pb6000 + More
    Scholar:
  • 150 Answers
Assuming all gaskets and lines were installed properly, try priming it with a little gas directly into carb, or remove spark plug and put a little gas directly in cylinder and see if it picks it up. Sometimes for first start this is necessary.
Posted on Oct 05, 2010
Starts right up and runs...dies when chocke is opened past half way
the carburetor needs to be cleaned or a new needle and seat installed. engines will start but may only run on choke, are starving for fuel. this means that the carburetor has a problem. usually a good cleaning and maybe a needle and seat will cure this problem.
Mar 12, 2016 | Garden
12.5 v twin , new fuel pump and filter. Cleaned carburetor Starts and runs as long as you pour gas into carburetor. will not run otherwise.
Open the gas cap, remove the fuel line from the carburetor and use compressed air to blow the line clear. Having done what you have already if the line was clear, you would have gas to the carburetor.
Nov 20, 2015 | Measuring Tools & Sensors
New carburetor - starts with full choke
Try you tube to see if they show you how to adjust it
Aug 21, 2015 | Garden
How do I connect the throttle to the carburettor on la125100 series
THis provide that it still the Briggs 331877 on it
Install Carburetor
NOTE: Always replace air cleaner gaskets and carburetor mounting gaskets any time the carburetor has been removed for service.
1. Position new gasket on studs with long edge of gasket opposite fuel inlet of carburetor.
2. Hook governor spring in throttle lever hole without grommet. Hook governor link in throttle lever hole with grommet.
3. Hook choke link into outer hole of choke shaft from underneath. Slide other end of choke link into slot in governor control bracket.
4. Position carburetor on engine. Install Carburetor to intake screws or nuts and torque to 70 in- lbs
5. Connect fuel hose to carburetor and secure with hose clamp.
6. Using new gasket, install air cleaner assembly to carburetor.
Adjust carburetor, if applicable.
7. After final carburetor adjustment, use Knockout Pin #19135 to install new limiter cap with flat side facing up.
Jan 08, 2015 | Garden
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
Murray riding mower will not start. Bought and installed new Champion spark plug, bought and installed new battery. Had fuse checked and it is fine. The mower sounds like it wants to start but will not...
This could be several issues. The most common is gum from the gas building up in the carburetor. To eliminate this as a problem pour a small amount of gas directly in the Carburetor. To access this you will need to remove the air filter. while cranking the mower after doing this "feather" the choke a little. These carburetors get gummed up very easily if left sitting for any period. it could be a matter of bad gas in the tank or possibly water moisture from condensation causing the issue as that will settle to the bottom of the tank and stop the mower from starting. Look in the tank and see if you have what appear to be dark colored blobs in the bottom of the tank, if you do that is going to be part of the issue. If the motor starts when you pour gas in directly in the carburetor the problem is most likely a need to rebuild the carburetor or with the fuel.
Jul 23, 2011 | Garden
Lawn Boy Silver Series mower starts and engine turns over but quickly stalls. Plenty of fuel in the tank, new clean oil and new spark plug. Air filter is clean too.
Hi wjingzus...
Check your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
May 14, 2011 | Garden
I have a Deere twin cylinder 23 hp Tecumseh tractor which is hard to start between uses. Per user manual, I choke it full and throttle it full. When I turn on the ignition it turns over and over and...
Hi knobbe69
Time to "mess" with your carburetor...sounds like that is where the problem lies...
I will include my instructions on the carburetor rebuilding....
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
Apr 16, 2011 | Tecumseh Ov691ea 22 Hp 22hp Lawn Rider...
Runs for about thirty seconds then stalls. New gas, plug installed. Runs for a second on full choke then stalls
Apr 13, 2011 | Dryers
Had new battery, carburetor, and fuel pump installed in my dodge aries 84, and still it wont start, why?
Have you checked that you have spark at the sparkplugs? Have you checked if the fuel is indeed reaching the carburetor? Have you checked if the choke is activated when you try to start it? If no find out why and fix it. Does the engine starts when you pour a small amount of lighter fluid directly in the carburetor? If yes then the carburetor is badly adjusted - fix that.
Mar 01, 2011 | 1984 Dodge D150
Echo Back Pack Blower Pipe Kit Pb4600 Pb6000 + More Logo
106 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
