Question about Mitsubishi VS-6085 60" Rear Projection Television
I have a Mitsubishi VS 6085, The problem is the TV has become dark even when I set the controlls to max brightness it is still dark, What can be the problem?
  • kjackson427 Oct 05, 2010
    I looked in the back of the TV and I did not see a bulb to replace, Can you show me the location?
    Yes that is the model of the TV VS6085. Can you send me a picture of where they are located?
    President:
  • 2,777 Answers
That is a lamp problem / bulb problem for sure. The tube is still working fine but the backlighting has failed. Do you think you are capable of changing the bulb yourself? It is quite difficult.. if so let me know and I can try to find the part for you.
Thanks
Tim
Posted on Oct 05, 2010
  • Tim Grayson
    Tim Grayson Oct 05, 2010
    You have taken apart the tv and can't find the bulbs inside? It is a VS-6085 rear projection TV correct? It definitely has bulbs in there I assure you, they are pretty deep inside the TV..
    Please confirm,
    Tim
  • Tim Grayson
    I don't have that exact model here, I am trying to find a picture or video online. Check youtube out, there are some replace lamp rear projection tv videos on there while I keep looking here.
    Tim
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
We have a Mitsubishi VS-50VA2 projection tv. The picture is very dim and the color is faded. Even after adjusting the brightness to the max, it is still dim. What do I need to do to fix this?
you need to clean the dust off lamps and the guns, if you don't know how. i can walk you thru it. but i would suggest having a repair shop do a full cleaning.
Jun 24, 2011 | Mitsubishi Televison & Video
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Mitsubishi VS-6085 power light flickers. when on, no tv controls work on the tv itself. universal remote will not control it either
BAD STKs replace both of them.STK392-570 M/B This number parts will have on them. they are big black ICs CAll MATs 1-800-628-1118.
Aug 19, 2009 | Mitsubishi VS-6085 60" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-6041- picture brightness not very bright
Hi Dawn,
The TV does have a screen control on each of the picture tubes ( there are 3 ) although I do suggest you have a qualified technician make the necessary adjustments as an improper adjustment can cause damage to the set. Should you deside to make these adjustments yourself, you'll need to remove the back ( or front in some sets) ( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE PREFORMING ANY ADJUSTMENTS INSIDE THE SET ) The screen adjustments are located either on the bottom of each tube or in a group component located where the main High Voltage Wire ( large red wire from the black transformer on the deflection board ) is connected to. Look for a turn pot ( screw type adjustment ) that is marked SCREEN. When you locate it ( whether it be on each tube or in the group component ) turn it up only slightly and not to much, as excessive gain ( turning it up to much ) may cause the TV to shut down. When you have the proper brightness ( when it looks good to you ) close the set up and enjoy the renewed picture. Good luck and I do hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Nov 18, 2007 | Mitsubishi VS-6041 60" Rear Projection...
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
