Question about Panasonic PV-GS83 Camcorder
After filming with the Panasonic PVgs83 camcorder , when it's reproducing the screen on the camcorder has blue stripes, what should i do?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
Panasonic pv-gs15 will not play back recorded video in the mini dv deck. all i see is a blue screen with red text ''picture'' on bottom right corner of the screen
Make sure your tape tab is open. See if this works. Sometimes the tab should be closed to prevent eraser or recording over existing film but sometimes the tape tab has to be open to allow for playback or dubbing?
May 28, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
Blue lines on panasonic camcorder playback mode
Mine is doing the same thing. It looks like the film holes on a 35 mm film camera or and old 8 mm video camera. It plays fine just can't get rid of the blue marks. Anyone with a suggestion?
Feb 09, 2010 | Panasonic Palmcorder PV-GS120 Mini DV...
Ag-dvc20p blue stripes in play back mode
Blue stripes in playback is an indication that you need to clean the heads. A Panasonic cleaning tape should work fine.
Jan 22, 2010 | Panasonic AG-DVC200 DV Digital Camcorder
My screen is striped blue during playback with no soud panasonic palmcorder pv gs15
Your tape has a small latch on it that closes to protect from recording or eraser and opens to allow for playing or dubbing. Slide it open and see what happens.
Sep 25, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Blue stripes when playback
first u put clean casset and try . again it coming then u chaing video head
Jul 21, 2009 | Panasonic PV-GS2 Mini DV Digital Camcorder
TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Mar 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Try to playback the tape and the screen is all blue
your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Jan 24, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Can not playback past end of first file on my Panasonic PV-GS2
I'm not sure if this will work for you but, sometimes I try to play back some of my tapes and a blue or grey screen comes up instead, although this sounds odd, if I record something(for even one second) it will let me see my film. I know this can cause problems because you may end up taping over film but if it's the only way to see your film it's worth a try!
Jun 02, 2006 | Panasonic PV-GS2 Mini DV Digital Camcorder
Panasonic PV-GS83 Camcorder Logo
66 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
