Question about Samsung SCX-4216F All-In-One Laser Printer
I'm trying to print and i always get a paper jam in door one. If I open the back door, the paper comes out 1 inch and stops. The paper is getting 95% printed on and then gets jammed. I changed the toner cartrige to see if that mad a differance, nope. Woundering what I should do next? New laser or repair, any thougths
  • 222 Answers
1. You have to clear paper feed roller
- to do this just follow simple steps:
- open fron cover
- remove toner cartridge
- use wet cloth (water or alcohol) to clear rubber feeder
- put toner cartridge back
- close front door
2. If the problem persist - chek all paper path sensors for lack of moving.
Posted on Oct 06, 2010
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but...
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Jan 01, 2014 | Minolta magicolor 2300W Laser Printer
HP laserjet 1518
HP printers frequently time how long a page takes to run through the machine. If it is too slow, they signal a jam error.
Try cleaning all the rollers and pinch wheels etc within the laser.
Dec 10, 2013 | HP LaserJet Office Equipment & Supplies
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
Out of paper
Cause: There is not enough paper in the input tray.
Solution: If the HP All-in-One is out of paper or there are only a few sheets
remaining, load more paper in the input tray. If there is paper in the input tray, remove
the paper, tap the stack of paper against a flat surface, and reload the paper into the
input tray. To continue your print job, press OK on the control panel of the HP All-in-
One.
Cause: The rear door is off the HP All-in-One.
Solution: If you removed the rear door to clear a paper jam, replace it.
rear door.
Paper can also jam in the automatic document feeder. Several common actions can
cause paper to jam the automatic document feeder:
• Placing too much paper in the document feeder tray. For information on the maximum
number of sheets allowed in the automatic document feeder, see Technical
information.
• Using paper that is too thick or too thin for the HP All-in-One.
• Trying to add paper to the document feeder tray while the HP All-in-One is feeding
pages.
To clear a paper jam from the rear door
1. Press in the tab on the left side of the rear door to release the door. Remove the door
by pulling it away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Paper specifications
This section contains information about paper tray capacities, paper sizes, and print margin
specifications.
• Paper tray capacities
• Paper sizes
• Print margin specifications
Type Paper weight Input tray1 Output tray2 Document
feeder tray
Plain paper 16 to 24 lb. (60 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 35
Legal paper 20 to 24 lb. (75 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 20
Cards up to 110 lb.
index (200 gsm)
40 10 N/A
Envelopes 20 to 24 lb. (75 to
90 gsm)
15 10 N/A
Transparency film N/A 25 25 or fewer N/A
Labels N/A 20 20 N/A
4 x 6 inch photo
paper
up to 145 lb. (236
gsm)
30 10 N/A
8.5 x 11 inch photo
paper
N/A 40 20 N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
HP recommends emptying the output tray frequently.
Paper sizes
Type Size
Paper Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Chapter 15
266 Technical information
Type Size
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium photo paper 102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
inches)
Top (leading edge) Bottom (trailing
edge)
Left and Right
margins
U.S. Letter
U.S. Legal
A4
Photo media
1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
Envelopes 16.5 mm (0.65
inches)
16.5 mm (0.66
inches)
3.3 mm (0.13 inches)
Print specifications
• Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
• Method: drop-on-demand thermal inkjet
• Language: Lightweight Imaging Device Interface Language (LIDIL)
• Print speed varies according to the complexity of the document
(continued)
Print specifications 267
Copy specifications
• Digital image processing
• Up to 100 copies from original (varies by model)
• Digital zoom: from 25 to 400% (varies by model)
• Fit to page, pre-scan
• Copy speeds vary according to the complexity of the document
Mode Type Scan resolution
(dpi)1
Best Black up to 600 x 1200
Color up to 600 x 1200
Normal Black up to 300 x 300
Color up to 300 x 300
Fast Black up to 300 x 300
Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
http://get.adobe.com/reader/
Also, once you have done all you can turn the printer off for a moment then turn it back on.
Hope this helps. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
173 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
