Question about Reddy Heater-30-55,000 BTU Variable
The heater doesn't ignite.. I push and hold the button.. but doesn't ignite
    Scholar:
  • 146 Answers
If you mean it won't stay running after the unit actually starts...meaning as soon as you release the red button it shuts off then you would need to clean the end of the thermocouple that screws into the gas valve....not the end that goes into the flame.
Remove the small nut and clean the end with a small wire brush or scrape some metal off with a knife, then scrape some metal inside the valve where the end of the thermocouple seats.
But if you mean it will not start at all then you need to make sure gas in getting through the valve.
Posted on Oct 06, 2010
2 Suggested Answers
noname2
  • 109 Answers
SOURCE: ignition button won't click down
Had the same problem. The HSI relay (SIEMANS T7CS50-24) on the circuit board went bad on mine. That part is hard to find since it's so old so I just got a panel mount 24V relay and soldered the two control wires to the correct locations on the board and everything is peachy. Most people should probably just get a new circuit board though.
Posted on Oct 30, 2009
When I try to start my mr. Heater I hold the pilot button down and the starter knob won't do anything? I can't get it to light the pilot, I've only had it a month.
Gas is turned on? Pilot button is in pilot position? Push and hold pilot button down, keep holding it down, push igniter many times, while keep holding down pilot button, keep holding until pilot lights. May take several minutes.
Feb 14, 2017 | Mr. Heater Heating & Cooling
My brand new 38 gallon GE water heater does not ignite. I follow the instructions, hold down button in pilot position, heater dial in pilot mode and push the piezoelectric button several times. I look...
Check that gas is turned ON. Gas handle is parallel same direction as gas line.
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Make sure that type of gas matches water heater. Natural gas and propane gas are two different types of gas. check label on side of tank for type of gas NG or LP.
Call GE 1-800-432-2737
Copy following links:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene
h
Aug 11, 2013 | General Electric Water Heaters
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instruct8ons
1) Just open the following link to identify gas control, and following instructions for lighting each gas control that appear under the gas control that looks like yours.
2) Otherwise add a comment and carefully describe gas control valve, and then open link and compare your description to pictures of each gas control valve, and then look below each picture for link that says how to light water heater.
3) Call plumber.or local service technician, or local BW supplier who can recommend technician.
4) Call Bradford White to get recommendation of local technician.
Trying to reset pilot light per instructions. Something is missing.
1) Copy following link to identify gas control valve:
2) Add a comment and describe gas control valve, and include if this is on boiler or water heater
GAS WATER HEATER PILOT WILL NOT LIT
assuming you mean you have electric ignition, DO NOT try to lite with a flame of any kind. make sure gas is on, while pushing knob turn to PILOT hold knob down for appr. 10 seconds while still holding knob down,push ignter. you may have to do this proccess afew times. if this doesnt work, call a pro. gas appl. can be extremily dangerous
Dec 21, 2012 | Water Heaters
My heater has a tapping when you turn on the ignition switch from lower passenger side. it doesns change with the fan speed but stops for a moment when the fresh/recirculation button is pushed
Try to replace the relay for the recirulation/fresh blower. I have a 1991 Chev PU and the relays are behind and below the glovebox compartment.
Mar 09, 2011 | Chevrolet 1500 Cars & Trucks
Igniter sparks after several tries but the pilot will not light
no gas is getting to pilot light. if all else fails change thermal coupling, if this is bad no gas will come out.
Nov 05, 2009 | Water Heaters
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Reddy Heater-30-55,000 BTU Variable Logo
101 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
