Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Where can i get a replacement freezer gasket for a sub zero 650 online?
    President:
  • 670 Answers
You can try midwestapplianceparts.com for a gasket.
Posted on Oct 05, 2010
How to change the freezer gasket on a Sub-Zero 650?
In my opinion this the easiest sub zero door gasket to install.The main reason for this is because of the way its packaged in the box from the factory.Not being twisted up makes it way easier then any of the others. And yes the first thing to do is remove the food and then pull the drawer out. Then loosen all the the quarter inch screws holding the metal strip that keeps the gasket in place but don't remove them just loosen. Once those are lose remove the old gasket. You should also remove the screws on the end of each metal strip. This helps when re-installing the new gasket. Now put freezer door face down with both rails sticking straight in the air and you can drop the gasket over the rails. The gasket has a small round bead that tucks in behind the metal strip. As you tuck this behind the strip work your way around the door snug in the screws be sure not to tighten them to much.Once in place take a hair dryer and warm any places that look wrinkled or need straightening. Finally tighten all screws including the eight corner screws now re-install freezer door and your finish.
Mar 25, 2014 | Sub-Zero 650 / O Bottom Freezer...
Replace freezer gasket
Lift the lip of the gasket from the side, and unscrew the screws holding the gasket holding bar. Rest is easily figured out how.
Mar 16, 2014 | Sub-Zero 650/SRH Stainless Steel
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero # 650 door adjustment
There are two covers on each side of the door. They are between the door gasket and plastic housing. Remove these covers to access the bolts. They are 3/8 I believe but cannot remember for sure. Loosen the bolts a little adjust door, tighten and test. Repeat till you get a good seal.
Mar 16, 2009 | Sub-Zero 650 / O Bottom Freezer...
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero Freezer Vacuum
If your freezer temps are ok, it may just be that your gasket is getting older and it becomes more porus as it ages. The vacume sound doesnt really mean alot except that the difference in the room temp and the cold of the freezer create this vacume.
Mar 08, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
94 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
