Question about Maytag MZD2766GES Side by Side Refrigerator
My MAYTAG - MSD2651HEB is only cooling on the bottom shelf of the freezer and refrigerator.
  • wendyzach57 Oct 05, 2010
    Unfortunately I have not been able to get any direction as to where to actually find the Defrost heater in my model to be able to test it
  • 17,970 Answers
From my expierance the problem is either mechanical or electrical in nature. First check all over the freezer and see if you have any frost. then push on the waiis and floor and see if you hear and crunching of frost or ice. If either of these tests show positive for frost or ice you probably have a defrost problem. The first thing to check is for a wire diagram or possibly for a code key that will tell you if your defrost heater circut is open or closed, and if you have frost you want it closed, If tyhe heater circut is closed then the only item left I can think of is the defrost iniator, or timmer depending on if its solid state or electromechanical. If the computer in a solid state lost memory on how often to defrost you may have to reprogram it or if this option isnt available replace the iniator assy.
Now if you dont have any frost - any where - you have covered most of the areas that can be, namely cleaning the unit. Now to the 1 clue that gives me the most insight is your "clicking every minute". This sounds verry much like a defective relay/overload/(possibly) capicator assy on the compressor or the compressor itsself. If you find the parts list look for all of these items and purchase them and replace them on the compressor. If it does the same thing - sorry its no go and your compressor is bad most likely. If it starts and sounds normal you may have another 5 to 6 years or more use. If Im wrong and the compressor is runnig and the click is something else then you could have developed a leak and lost all refrigerant. (I wouldnt believe so from your discription of the clicking, this usually dosnt happen on loss of a charge but it can). If Ive got you lost Im sorry. Tell me where I lost you and I'll try to help ya over the hump.
Keep us updated.
Posted on Oct 05, 2010
Maytag-refer & freezer get cold & not cold- off & on cycles
are you able to pull the refrigerator out unplug the power cord from the wall and take the back cover off of the bottom back side near the floor of the refrigerator? The problem could be related to the start relay being defective run capacitor these are parts that start the compressor and keep it running. The problem also could be a defrost control board found in the control panel inside but the way it sounds it's the start relay from what it sounds like from your description I just need to know if the compressor is clicking and hot
Appliance 911 Sea Breeze
Sep 18, 2015 | Maytag Refrigerators
Refrigerator won't cool but the bottom freezer works
under bottom shelf there are air inlets to fridge take out tray clean ice frominlets
Jul 22, 2012 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator model msd2651heb not cooling. Hear fan running but not condensor
if you mean the compressor isn't running most likely you have a bad start device part 67005560,pull out machine unplug it and remove the bottom back panel,look at compressor,pop off metal clip and remove cover on the side of compressor,slide off the device and shake it,if the device is cooked you'll hear pieces rattling around inside it,install new part,if it still doesn't start could have a bad compressor.
Jul 14, 2012 | Refrigerators
Maytag model GS2127CAHW duel cool fridge freezer is not cooling very well on the fridge side. Sluggish and running at 11 deg C on the top shelf on maximum.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | Refrigerators
Refrigerator not cooling it is a maytag with freeser at the bottom freeser is maintaining temp
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Maytag MFD2560HES Bottom Freezer French...
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
98 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
