Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
Motorola razr2 v9
Hi had this phone for 6 days, battery lasts on a full charge 3-8 hours, even after letting the battery drain and fully recharging it over night. now all of a sudden for no reson it says invalid battery all the time. have tried evrything, removeing the battery, charging it switched on, switched off, nothing gets rid of this error, HELP!! thanx.
  • Anonymous Mar 13, 2014
    I have tried letting the battery go flat and recharged it to try again to switch the phone on however this has made no difference
    Genius:
  • 1,224 Answers
It sounds like a one in a million defective battery goto service phone tech show them your receipt and have them replace this battery
Posted on May 28, 2008
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
Apr 08, 2015 | Tracfone Wireless LG 440G
Need subsidy password for motorola razr2 v9
You can get the Motorola RAZR 2 Subsidy Password at here Mobile-unlocker.com/motorola-razr2-v9/rs2wp9/ AND unlock it FROM 3 Network lock.
Dec 11, 2011 | Motorola Mobility RAZR2 v9 Cell Phone
Hi ive got a samsung galaxy s2 and the battery life is really bad. I will charge the phone fully over night and ut wont even last half a day. Is this a commen problem or do u have a dodgy battery
How old is the phone/battery?
Has the battery been fully discharged (used until it will not power up the item) very many times?
This is very bad for Li/Po batteries. If the phone is less than 6-12 months old, I would contact my cell provider and ask for a replacement battery. In lieu of your provider replacing it, your only option will likely be to replace it yourself. Unlike the old-school Ni/Cad rechargeable batteries, Li/Po batteries lose their ability to hold a charge if they are drained fully too many times. Also a good tip with a new battery is to charge it longer than just until the battery power indicator is full (overnight is a good basic rule, but check your phone's user guide or google the specific battery model for recommended charge times) for the first few charges, and avoid letting it fully discharge. Try to get it on a charger with at least 1 or 2 bars left. This will increase the life of a cell phone battery dramatically.
hope this helps,
r
Sep 12, 2011 | Samsung Cell Phones
Need Help : Even after placing the charger into the (Motorolla V9 ferari) phone , it still displays " Battery Low , cannot program " Boot loader 05.80 SW Version R263313-AS_u_A 0.03.2FR
the problem is from the battery.
the battery is bad and needs to be replaced with a new one.
so, go to a nearby motorolla outlet purchase a new battery, charge for an hour before putting ON the phone..
NOTE; do not switch on the phone until the battery is properly charged.
Jan 11, 2011 | Motorola Mobility RAZR2 v9 Cell Phone
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
My motorola motor razr2 when i put charger in it starts to charge and phone turns on and green charge light goes out and it stops charging
ok this can be numerous things lets start with slide the charger cable out gently see if at any time it starts charging as you do this. No 2 could be the battery getting week, and loosing a cell in it. No.3 this is a software glitch that the phone needs for the software to be reinstalled which will take a technician familiar with modding and software.
Jun 19, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Unlock the 3 uk moto razr V9
you can bring your mobile to a service center and let them open the line to you or activate using their software.
thanks,
Jun 28, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
177 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
