Question about Toshiba REGZA 46RV530U LCD TV
Toshiba Regza 42XV55D - Tv less than 2 years old - problem with switching on - no lights showing. For a few weeks the on/off button on left side has been airy/fairy. Sometimes pressing switch has put tv into standby, sometimes switched off, sometimes powered it up - Fuse in plug tested ok - any suggestions
skotkolr
  • 558 Answers
SOURCE: Weird lines on Toshiba REGZA
its in warranty ship it, the problem is actually not common but it is a problem it is related to the processor on the main board, and um don't trust salesmen to tell you about repair issues. They really don't have a clue. if you need a tv for to weeks then rent one for two weeks they are not that expensive to rent
Posted on Aug 23, 2008
romsky79
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
Posted on May 28, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
SOURCE: bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Posted on May 11, 2010
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
No picture, no sound, but TV will power up
Average life on all brands and models is 3 to 5 years. Average repair on this size and type of set varies but is usually from 150 to 250 parts and labor. I see very few sets of this type (any brand) that are more than 6 years old.
The bulk of sets in our shop (over a hundred sets on average) that have failed are under 2 years of age.
Dec 20, 2012 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Am having the same problems. The TV is on standby (red light on front) but wont turn on from the remote or from the side of the set. This can last 1 or 2 days, then it works fine again for another week,...
There is a problem with the power switch board,there might be short in the IC Unit , you might have to change it. get it serviced by a TV electrician soon before the board gets damaged.
thanks for rating good luck
Feb 08, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
3.5 " top to bottom area on left side clear and brite like HD but about 80% of the entire screen to the left of this is slightly duller as if there is a shade over the left side. TV is less than 2 years...
the backlighting in the tv might be going out. that is the first hing to look at. it might also be the liquid crystal display itself. you can look for the backlighting yourself by unscrewing the back panel from the lcd tv. and simply turning it on. you will see if one of the lights is dimmer than the other or just simply out. if you dont want to do that yourself take it to a tv shop and just have them look at it. most tv repair shops coast to coast dont charge to look at it for you. if one does go to the next. they are in just about every city. (checking it for free) hope this is helpful
May 10, 2010 | Toshiba REGZA 37RV530 LCD TV
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
Bought a Toshiba Regza 37rv635d last week.
Apr 06, 2010 | Televison & Video
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
No picture, just sound
No new video card required. I just reset the television by holding the on/off button for five seconds (yellow light on front panel blinks repeatedly). I then cycled power using the remote control and my picture came back. Worked for me. Hope it works for you.
May 19, 2008 | Toshiba 32A3000 32A3000 32 16:9 Multi...
Toshiba REGZA 46RV530U LCD TV Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
