Question about Muratec Office Equipment & Supplies
Muratec F-110 fax machine can send faxs but does not receive, i tried different phone lines, changed configurations changed toner, drum. nothing seems to work thanks, rick
    Genius:
  • 1,218 Answers
Make sure the machine is in Fax mode and NOT Tel mode. Other thing to try is to pickup handset and listen to see if you hear "Dial-tone" from the line...if you don't then you have probably lost part of the NCU pcb in the machine.
Posted on Oct 10, 2010
Having a clicking noise problem when installing a new toner cartridge into the fax machine. Reusing the old cartridge makes the noise go away. There is nothing wrong with the new toner (we have 2 and both...
You state that you have 2 new toners and both make a noise, but the old one does not. If both the two new toners came from the same source then it is possible that the vendor has a quality control problem and manufactured several defective cartridges. It does happen. If these are not genuine Muratec toners, that makes it all the more likely because often they are remanufactured and attention was not paid to details. Is the old cartridge from the same vendor and does it bear the same brand name if it is not a genuine Muratec item? 15 years in this business tells me that if the old one is quiet and the new ones are noisy, something is wrong with the cartridges, not your machine.
May 05, 2011 | Muratec F320 Plain Paper LED Fax
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Can't get incoming faxes.
My HP did this same thing and the solution was replacement.
May 21, 2009 | Muratec MFX-2000 Plain Paper Laser Fax
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Muratec F360 Plain Paper Laser.. i need to change the time
What is printed on the top of your received fax's is determined by the sending machine. If the user at the other end does not have name ,date and time programmed into their machine correctly then you will get printed on the top of your received page whatever is in their machine.
Jun 18, 2008 | Muratec F360 Plain Paper Laser Fax
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Apr 18, 2007 | Muratec F360 Plain Paper Laser Fax
166 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
