Sharp Aquos 52 inch LCD devolped a thin black horizontal line the goes 80% across the screen about 2/3 up from the bottom. Looks like a telephone wire when there are outdoor sceens.
  • 4,889 Answers
You have a bad t-con board, the most common cause of this problem. It is the LCD controller which is responsible for producing an image on the screen. Replacing it should resolve the issue and component level repair is not possible as the board is full of solid state electronics. The board is relatively inexpensive and should cost you about 125$. It is easy to replace as well if you have the basic know how of electronics(what not to touch, how to remove connectors etc.,) If you want to do it yourself then let me know and I will see you through this.
PS: In rare cases this can also be caused by a faulty panel which I hope is not the case with your set.
Posted on Oct 05, 2010
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My 52 inch sharp aquos has green and black vertical lines across the entire screen
Try different source like VCR, DVD, or satellite to see if it is the source thats bad.  Check to see all your connections are on good and tight.  If still no luck, then your tele is fu.k.d and you got bad LCD crystals or faulty inverter.  Take the thing back to the store for exchange or refund if your within your 30 day window.  Call the manufacturer if your within your 1 year window.
Oct 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Sep 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Thin line across the screen
I'm guessing that this is a CRT based TV, not an LCD. That being said, the problem is a failure of the vertical circuit. Usually this is a small flat IC (LA7837 or similar). Try resoldering the pins if you can first. If that fails to resolve the problem, replace the IC. Please be aware that there are potentially dangerous high voltages present even when unplugged.
Keep us posted.
Dan
Jan 21, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Line in middle of LCD screen
I too had a black line horizontally across the screen (on a 52" d62). It was brand new and was as if the screen had been "pinched" at the end of the line and it radiated outward (in my case, the "pinch" was at the extreme left and line went out to the right, like a crack).
Mine was a factory defect (right out of the box) and was replaced (2 yr now and no issues). This line of yours may have been there from the start and maybe you just didn't notice it?? Not a slam, just an observation.
Feb 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
