MY epson 4800 is giving a code 001001d whats this mean and how do i resolve this code. Thanks
  • yan dikshteyn Oct 05, 2010
    need solid steps to fix error
    thank you
    Genius:
  • 1,456 Answers
Hello
This means your print head is clogged and you should clean the print head.
Make sure that the "Encoder Strip" is also clean and in the channel for the sensor located on the back side of the printhead carriage.
Posted on Oct 05, 2010
    President:
  • 3,278 Answers
Hello.
Could be referring to a hardware error.
But first, look at your print head. If your print head is on the left, turn the printer off and back on. If your print head is in its normal docking positon, move it to the left and turn printer off and back on.
Hope this helps.
  • NinaE Oct 05, 2010
    So, moving the print head didn't make a difference ??
Epson Stylus Pro 4800 printing problem
Communication error typically means that your printer and computer aren't talking. Assuming you're using a USB cable, try a replacement cable, in another socket on the computer.
Dec 21, 2015 | Epson Stylus Pro 4800 InkJet Printer
I am getting the error message code 154E - is there anyway to fix this without getting it serviced?
According to:
Error Codes Epson Stylus Pro WT7910 Code 154E
you have a "Velocity deviation error"
meaning that the print head isn't traveling at the correct speed. Clean and lubricate the shaft it runs on, the above site also suggests replacing cutter unit and/or main board.
Jun 15, 2015 | Epson Stylus Pro 4800 InkJet Printer
How to change dampers on Epson 4800 printer
For instructions to replace dampers in your Epson 4800 printer, you will need to follow the Epson repair manual, which you can get fromwww.2manuals.com.
I know others have posted helpful videos on YouTube, but we have not made videos that show printer repair or component replacement.
From my own experience, I can tell you the process will go easier if you thoroughly read the procedure (or watch the video) before starting to get an idea of what's involved, and use a magnetized screw driver. I like to keep screws/parts together to know what goes with what to avoid confusion when putting it back together, so use small plastic bags to tape screws to parts they go with. Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
May 16, 2014 | Epson Office Equipment & Supplies
Service error 001001d
move the unlock green piece...
en el cabezal de impresion, mueve la pieza verde a la izquerda y listo!!
saludos
Jaime Fierro
Dec 07, 2010 | Epson Stylus Pro 10000 InkJet Printer
Printer won't take my Ilford Gold Fiber Silk
Did this ever get resolved. I am having the same issue! Thanks, Carolyn
May 14, 2010 | Epson Stylus Pro 4800 InkJet Printer
Epson 4800 bad quality printing
Did you use Epson Genuine Cartridges? I have an epson 4800.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus pro 4800 field repair manual
Epson is pretty cautious with their proprietary materials.
Oct 30, 2008 | Epson Stylus Pro 4800 InkJet Printer
Error code 00010030 signifies that there is some failure with the Multi Sensor. The Multi Sensor is located on the Printhead Carriage, and consists of a blue light, and the sensor itself. If you look at the Printhead Carriage, you'll notice a graphic of a pair of scissors on the side. Right below that is where the sensor is located. Dust, debris, and excess ink may have accumulated over the sensor, causing it to give a false error code. Clean it, and if that doesn't work, replace the sensor.
Oct 29, 2008 | Epson Stylus Pro 4800 InkJet Printer
341 people viewed this question
k24674
jasbo
jasbo
