Question about Precor 9.21 Treadmill
Broken motor cover - Precor 9.21 Treadmill
  • 95 Answers
There are a few different versions of the Precor 9.21 treadmill but FitnessRepairParts has a motor cover that it says is used for several of the models: http://www.fitnessrepairparts.com/cart/ViewItem/5005569
Posted on Oct 05, 2010
Where to buy trimline 7050 motor cover(plastic)
Trimline Treadmill ' eBay
www.ebay.com/bhp/trimline-treadmill
eBayGREY TRIMLINE TREADMILL MOTOR HOOD HOUSING KK-2439 FRONT ENDCOVER PLASTIC. $45.00. Buy It Now. This auction is for a good used treadmill ..
Jan 05, 2016 | Exercise & Fitness
Hi i have this chainsaw as mention below.i need a replacement part.its the black cover that fits on both sides of the motor that covers the the rubber stopper that stop the motor moving.there are 2 .
Sounds like you will have to pull the cover part of pull cord there is a spring under cover it could be broken or needs cleaning and lube also spring tension could be slack and not returning cord properly or very dirty under there be careful as spring could also be broken
Feb 10, 2015 | Garden
Tap and drill a broken water pump stud on a 1999 ford explore eddie bauer
ARE YOU TALKING ABOUT A STUD OR A BOLT? THESE MOTORS HAS 4 LONG BOLTS THAT GO THRU THE TIMING COVER , IF THIS IS WHAT IS BROKEN THEN YOU WILL HAVE TO REMOVE THE COVER, THE BOLTS GET CORRODED IN THE COVER AND OFTEN BREAK. IF THIS IS THE CASE THE COVER WILL BE EXTREMELY DIFFICULT TO REMOVE AND WILL MOST LIKELY BE DESTROYED IN THE PROCESS. GOOD NEWS IS THE BOLT COMES OUT EASY ONCE YOU GET THE COVER OFF. GOOD LUCK, YOU ARE GOING TO NEED IT!!
Dec 08, 2014 | Ford Cars & Trucks
91bmw 3181 coolant drained. Connection fr rad to motor appears to have broken at motor. Not enough to connect back up. Piece on motor too short. Is it much work to replace the piece on the motor
At the motor? That is odd. Is the part plastic? BMW currently sells a metal thermostat cover for this car. The 6-cyl BMWs used a plastic thermostat cover which failed routinely.
The BMW thermostat cover should cost you about $50 at the dealer or $40 on line. Gasket is sold separately. You will want to replace the thermostat while you have the thermostat cover off.
Jul 30, 2011 | BMW 318 Cars & Trucks
Kenmore 417.41052000 front load washer. Fills and drains, door lock light comes on but no agitation or spin of any kind. Belt good, power to board good. Motor ohms 3.8 and is supposed to ohm at 2.6 +-%7....
The best condition for you would be a broken belt. That can be seen by first removing power to the product. Remove two srews from the rear of the top cover. Slide the cover back slightly while lifting up on the rear. A large pulley will be visible on the rear of the tub, and this pulley should have a flat belt on it. If you see the belt, and are unable to lift it up, then it's not broken. At that point you should consider calling a qualified service technician to diagnose your problem. It can be a failed motor (your unit has two motors.....one is the drive motor, the second is the pump motor), a failed motor speed control board, or a bad electrical connection.
Nov 22, 2010 | Kenmore Washing Machines
The window falls down I tape it up but the motor works
I am not familiar with Alero's, but my guess would be the window regulator is broken. The motor pulls a cable which is attached to frame that bolts to the bottom of the window. The cable connecting to the frame (or motor) is probably broken.
You will have to remove the door cover. This involves finding a few screws and removing them, then gently prying off the cover. Search the net for details.
Feb 20, 2010 | 2002 Oldsmobile Alero
Model is JES1451. Turntable won't turn. I removed the cover and the motor and the shaft appears to be broken. How do I remove the broken shaft and replace the motor?
Hi the shaft should just pull up, to remove the motor you will need to turn the oven onto it side, you will see a cover at the bottom of the machine to remove this you will probably need to cut through three of the tabs, you can then gain access to the two screws securing the motor.
When replacing the cover turn it over and fix using the spare self tapping screw to be found in the base near to the cover you just removed.
Hope this helps
Jan 05, 2010 | GE JES1456 Microwave Oven
My bmw 318i roof dont open i can hear the motor but it does not open can u help does it need reprograming
Has the motor jumped track or a belt broken, or a spiral gear broken, take the cover off where you hear the motor and see if you can in there with a light.
Nov 06, 2009 | Washing Machines
I have a serger sewing machine the motor is running but the needles dont move
It sounds like you have a broken belt. The belt connects the motor to the large handwheel on the right side of the machine. Usually the side cover comes off with just a couple screws and exposes the motor belt, however some require removing the back cover also. You should be able to get a belt at your nearest sewing machine repair shop. Take your old one with you so you get the correct size.
If you open the side of the machine and the belt is not broken. The pulley on the motor may be damaged.
Oct 09, 2009 | PfaFF Sewing Machines
Motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Dec 19, 2008 | Cuisinart DFP-14BC Custom Food Processor
Precor 9.21 Treadmill Logo
690 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
