Question about Sony Playstation 3 (PS3) Console
No power i used it it worked fine i came home that evening and it wont power up is ther a fuse in this box
  • Anonymous May 29, 2008
    It worked fine the day before but when I came home it wouldn't turn on. I tried to use it in different outlets but no luck. I took the plug out of the console and put back in but still no luck. It must be a problem in side my ps3.
  • 207 Answers
Ok you have a fried Power supply!
You cant do anything about it, UNLESS it is under warrenty via sony! Call them up and ask. I can help you get new parts and replace it or I can buy it from you broke!
new power supplys are about 120$
Posted on May 30, 2008
When jumped my truck runs but wont start again. i replaced battery and it still wont start
check the resistance on the wires from the battery to your fuse panel and your ground wires also check to make sure you have good connections inside your fuse box if all is good there try to bench test the starter by applying a direct 12 volt power supply to.
Nov 20, 2013 | 2001 Dodge Ram 2500 Truck
Right signals not workin and some fuses are not workin even when chage
while the fuses not working is normal for most of the cars system, it appears the multi-switch is broken. ther fuses will be fine, and most likely have nothing ot do with the turn signal problem.
Mar 10, 2011 | Mazda 929 Cars & Trucks
My N7 M17FBA monitor wont turn on anymore. I was using it fine and got a new monitor for home and took the N7 to work. However when I got there it wont turn on. The power AC box shows a light but nothing...
It can be poor dolder joint s where the DC input jack is on the board, or it may have blown the fuse inside, you need to check that first.
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find.
Sep 07, 2010 | Scanport 17" LCD Monitor
Signal lights wont work
check under the hood on the leftside ther is a relay box ther is a relay next the word flasher replace it .
Jul 07, 2010 | 2004 Hyundai Elantra
'95 400V 16v. Melted fuse gave lights etc, new one no power
It will be a lot of trial and error testing I am afraid, this is a problem that needs to be traced out to find the source of the short.
Feb 11, 2010 | 1992 Suzuki GSF 400 Bandit
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
Ford taurus fan problems.....When I was driving the one fan worked fine but the air conditioner fan that kicks on when used, It would not work...... Now I get home and look at it and I test it motor and...
Your car has a fan controller box, it can be self tested by the dealer, suggest u have this test run, one last thought have u hooked power to the fan motor to see if it is working, they do burn out as they run the most of the two fans.Is the compressor running?
Jun 18, 2009 | 2000 Ford Taurus
Carolla stereo wont turn on..
Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
Nov 09, 2008 | 2004 Toyota Corolla
Wont start
resistor.............tell the mehanic
Jun 27, 2008 | 2003 Dodge Caravan
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
