Question about Kenmore 89182 Dryer
Dryer runs but no heat...does it have 2 fuses like other dryers?
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Indesit idc85 will not work or heat up
follow this steps and fix it. God bless you
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gWEW0sFp
Oct 01, 2013 | Indesit Dryers
Dryer does not heat up even fuse is good , what next can the cause and check. thanks
1. No power to the dryer
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
Oct 01, 2013 | Dryers
Heat starts and then dies and never goes back on but dryer keeps spinning
2. Heating element
3. Thermal fuse
Oct 01, 2013 | Whirlpool LGR6611L Gas Dryer
Change a four prong cord to three prong cord, dryer heats, turns but does not dry, vents have been cleaned
test this steps and fix it. God bless you
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2ab3IwDXf
Jul 31, 2013 | Frigidaire FEQ332E Electric Dryer
Dryer spins, but no heat...please help :)
follow this steps and fix it. GOD BLESS YOU
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2Ybcyu6Us
Jul 09, 2013 | Samsung DV419AE Dryer
Dryer not heating, but the heating element looks fine
If it is a 220V. dryer.. it needs 2 fuses. One runs the dryer motor and the other one runs the heating element. Check the main fuse box. Turn off main power before messing with any fuses. Look for 2 big fuses, probably in their own block. You can switch these 2 around and try the dryer again. If it does not come on, then the fuse is bad and needs replaced. If nothing is any different, then the element may need replaced.
Oct 13, 2009 | Roper Dryers
Maytag Atlantis electric dryer Model
Check the following to address this issue.
2. Heating element
3. Thermal fuse
Aug 08, 2009 | Dryers
Ihave a kirkland signature dryer model#seds800jqo dryer runs but
2. Heating element
3. Thermal fuse
Jul 23, 2009 | GE Profile DPXH46EA Electric Dryer
Dyrer runs no heat cannot locate fuses
2. Heating element
3. Thermal fuse
Jul 20, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
2. Heating element
3. Thermal fuse
Jun 02, 2009 | Whirlpool Dryers
Dryers Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
