Question about Black & Decker Garden
I'm using a black and decker planer (kw710/711/713) and the motor is running but the blade isn't moving, do you know what this problem could be?
  • 520 Answers
Most of these have a drive belt. i would check that first. here is a picture of what you are looking for. could also be some stripped gears so check it all.
http://www.tool-net.co.uk/p-316866/black-and-decker-dn710-dn720-bd710-kw710-planer-drive-belt.html
Posted on Oct 05, 2010
Neuton cordless hedge trimmer may need new motor. the blade does not go back and forth
Primary gear on motor shaft may be stripped, no source for replacement known. I have the same problem motor runs but blades do not move.
Feb 19, 2012 | Black & Decker Garden
I'm looking for replacement blades for black&decker plane mod 21286 or part # 7696,i need set of bldes
Any Internet search will yeild sources. You may find that HSS blades are more $ than carbide ones, IMO because the carbide are old-stock and have not be repriced.
But first make sure you need replacement blades. Initially because the blades are reversable, and 2nd, either the adjusting height control is not functioning OR, and was in my case, the lower plate with 2 screws has slipped inwards. Since I believe the blades slide out after the top plate (3 screws) is removed, do NOT move the lower plates
Oct 27, 2010 | Black & Decker 2 pc. Planer Replacement...
How do i remove the blades from a black and decker 7696 planer
Solution of they-slide-out (losen any screw instead of removing same is always advised) is part of another answer on this site:
http://www.fixya.com/support/t6578544-looking_replacement_blades
BTW, my supplier of replacement belts can not obtain more belts..
Jun 17, 2010 | Black & Decker 2 pc. Planer Replacement...
Planer no. kw715 spare blades black and decker please supply
The replacement blades for a Black and Decker KW715 portable planer are Black and Decker part number X24192. It looks like there are a number available on Ebay.co.uk at the moment.
There are also third party replacements for these blades. Trend PB/29 blades should work as well.
If this answer was useful, please vote for it. Thanks!
Jun 14, 2010 | Black & Decker Tools & Hardware - Others
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Hedge trimmer blade not moving
I have a Troy-Bilt gas powered hedge trimmer. My blades would not move. After tearing it apart, I found that there were some spacers under the 5 or 6 screws along the blades. These spacers are steel and designed so that you don't overtighten the screws. However, around those steel spacers, there is a teflon type material that makes the oval shape of the slot. That teflon had fallen apart and lodged so that the blades would not move. I removed the teflon and put the spacers back in and it now works fine. There is a little play between the spacer and the edge of the slot and it will probably eventually wear out but at least I got a few more cuttings off of it.
Jul 04, 2009 | Black & Decker Black Decker 16" Hedge...
I need a copy of the owners maual for Black n Decker. When I turn it on the blades do not move but the gears inside are moving. Therefore it screams. Thanks.
Do you use WD40 on the blades between sessions
If you have been cutting resinious branches there is more than a chance that the blades are seized together.
You could try putting the blades into a bucket of very hot soapy water (Without a power line attached or the battery removed )
Leave them to soak for a couple of hours, take them out of the water and give them a try, if they run then dry the blades off with a hair dryer and apply some oil to the surfaces.
If they donT then you have stripped the teeth on the gearbox and you may as well dump them as it will be cheaper to buy a new machine than it is to get B&D to repair it
Jun 16, 2009 | Black & Decker Black Decker 16" Hedge...
Garden Logo
231 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
