Question about Whirlpool Dishwashers
The clean light blinking. unable to start/resume or cancel/drain. the machine is now unoperational. please help solving this issue as soon as possible.
  • 1 more comment
  • saykruoch Oct 05, 2010
    Currently, I'm at work. Will try the solution 1 when I get home this evening. I'll let you know.
    Thanks,
    Say
  • saykruoch Oct 06, 2010
    I did the solution 1 last evening, but the same problem is still there. Please advise me with the differents solutions if possible.
    Thanks,
    Say Kruoch
    I was trying the solution 1, but there were no successful. Please advise me with different solutions if possible.
    Thanks,
    Say Kruoch
  • 10,865 Answers
Here is a link to an excellent video from whirlpool which outlines the causes and fixes to this annoying issue. Joe http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
Posted on Oct 07, 2010
  • 5,081 Answers
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Check this link too
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
COURTESY: JS ROCK -One of the best experts of fixya
Check this video
http://video.google.com/videoplay?docid=-973702559038457901#
Posted on Oct 06, 2010
    Brigadier General:
  • 3,513 Answers
The problem is usually attributed to water supply temperatures being too low when filling.There is a reset sequence that you can try to clear the fault.
To do so hit the keys in the following order. .
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again..the pressing of the buttons takes several attempts. the lights on the front panel will all light up and the washer will go through a cycle. it will be fixed upon completion of the cycle
To keep the fault from returning, you are suggested to run the hot water faucet in the kitchen until it runs hot before you start the dishwasher. This will heat the water in the supply line for the dishwasher .If you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines especially if you have a hot water tank located far away from the outlet, this should satisfy the requirements of the temperature sensing circuits.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 05, 2010
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Please tell me how to reset my i9950 printer once the ink tank has been cleaned
Try this:
  • With the printer plugged in and powered off, press and hold the "Resume/Cancel" button, then press and hold the "Power" button. Do not release the buttons. The LED will be gree.
  • While holding the "Power" button, release only the "Resume/Cancel" button.
  • While holding the "Power" button, press the "Resume/Cancel" button 2 times, and then release both the buttons.
  • When the LED light is green, press the "Resume/Cancel" button 4 times.
  • Press the "Power" button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  • Press the "Power" button to exit service mode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Office Equipment & Supplies
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4200 flashes orane 5 times
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
time(s) setting).
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
I'm getting a message that my overflow ink tank is full. How do I fix this?
You can reset the waste ink counter:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
However, you also need to blot the ink out of the waste ink absorber. The "tank" is a pair (usually) of plastic squares with a small piece of absorbant pad in the square on the sides of the carriage. For best results you need to partially disassemble the printer. Some find just drying the pads on a bunch of towels until it stops transferring ink is sufficient. (Also dry excess ink from around the plastic.) Otherwise, rinse the pads until the water runs clear. Then let the pads dry (blotting helps) completely. Without the cleaning step, you can get ink smearing on the back of the page as well as inside the printer.
I hope this helps.
(the counter is set to a number of pages that is the expected lifetime of the printer under normal use. Other failures may come up soon.)
May 19, 2010 | Canon PIXMA iP90 Mobile Printer
Getting Waste Ink Asborber is Full message, What do Ineed to do to fix it?
The waste ink absorbers are usually small pads at the bottom of the printer. You need to pull them. This is usually messy and can require basically taking apart the printer. Then either replace (contact a service center) or rinse clean the pads (just running water works). Once the pads are dry (if reusing them), reinstall them.
Then reset the counter:
Do not do the reset until the ink absorber is cleaned. The waste ink will get everywhere in the printer and the pages you print.
I hope this helps.
(most ink jets are really designed to be replaced if the waste ink absorber is full - the other parts may soon fail too.)
May 02, 2010 | Canon PIXMA iP90 Mobile Printer
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I get a message telling me that the waste tank absorber is full. Could you solve this problem for me?
Try this to reset the error.
Sep 12, 2009 | Canon PIXMA iP90 InkJet Printer
Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Jul 05, 2008 | Canon BubbleJet i70 InkJet Photo Printer
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
64 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
