Question about Brother HL-2070N Laser Printer
Will not feed paper
Makes loud clicking noises but paper remains in tray. Have changed paper and reversed sides but still bangs away. Works OK on single feed. Help !!!
  • Ringocop May 28, 2008
    In case it was not made clear the printer is a Brother 2070N
    New Friend:
Before I had checked all of the above I pulled the main paper tray out to inspect the paper, tray, and gears, this time after a cooling down my frustration level. I found a simple answer: The paper size setting tab had moved. Even though I had a second paper feeder, and had tried swapping the paper trays, that did not work since that paper size setting tab was off as well, probably due to slamming the tray home in frustration. Ahhhhh, technology, you are my mistress.
Posted on Mar 09, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
No paper feed and Loud clicking noise. REPLACE CARTRIDGE.
[TONER CARTRIDGE HOLDER] COULD SOLVE YOUR PROBLEMS. roller could be jammed stopping the gears driving the roller. remove the toner cartridge try to move the gears on left back corner.[DO NOT FINGER THE ROLLER] BEST REPLACE. But if you are brave...if you can't move the gear drive,
lube the end at the no gear end,, Perhaps best to buy a new carier...
Posted on Sep 04, 2014
    Novelist:
  • 85 Answers
Hi I had a similar problem with an HP on looking inside I found a pen top had fellen into the paper feed rollers. Check there is no obstruction.
Posted on May 29, 2008
  • 89 Answers
Sounds like the gears are out of alignment for the paper pick up tray.
  • JNagarya Sep 11, 2012
    To which gears do you refer? Do you even know anything about this specific printer?
My 2001 tahoe makes a loud clicking noise in forward motion. The faster you go and the warmer the vehicle is it goes away. Then in reverse it makes a loud scraping noise. Help plz.
how well does reverse work and check color and level of trans fluid with engine running and warm also feel for grittyness of fluid if gritty and browning your trans may be going out
Apr 01, 2012 | 2001 Chevrolet Tahoe
Printer makes a horrible sound when trying to print also the blue button on the right side making a loud clicking noise. the paper won't feed.8860 dn
I have had the exact same problem. The problem is in the tray. It won't raise the paper properly despite how much paper you have in it. Make sure that all of the springs are there, and that the plastic sensors are correct.
I've found it useful to just buy another tray. You can find it as low as $30-35.
It's a very typical mechanical problem, but most likely resolved by changing the tray.
Apr 01, 2011 | Brother MFC-8860DN Printer
Paper will not feed from tray and makes a loud clicking noise. Says there is no paper in tray
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
If the rear guide is tight, or even snug, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, you will see calibration marks for the paper size you are using. Unlock the rear paper guide, squeeze the release, and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Jun 18, 2010 | Brother MFC-8860DN Printer
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Makes a loud banging noise while the paper will only feed in an inch or so
A bang for a buck. July 25, 2009 8:06 PM RSS feed for this thread .... These paper noise-makers are pretty loud. And you can make them with ... It's just a folded piece of paper so it's pretty inconspicuous. ... more decibles per square inch than about anything else on this list, and hey, they shoot streamers! ...
ask.metafilter.com/128391/A-bang-for-a-buck -
Dec 04, 2009 | Samsung ML 1430 Laser Printer
Clicking noise with MFC-8640D another case
Usually it's because the paper is too tight in the feed tray. The paper length tab on the end away from the feed roller is too tight. If you cant rotate the gear on the paper tray and lift the paper, it's too tight for the machine to lift.
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
Keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Jan 19, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Noisey vibration
Dear Rab,
Hope this solves your problem. I understand that you are having problem only on the reversei side tractor feed problem. We have encountered same problem even in different models and brands. Please check the Lever Paper Fed Selector is engaged well, so that the gears give less space clearance to each other. Please check the tractor tray is locked tightly both ends. Please check if the grease on the paper tray and contacting gears are not dried up. Please check also the paper path if there are remains or clogged parts of paper perforation holes. Finally check the flatten (stainless still or hard plastic) paper against the roller if not to tight. You can check manually by turning the paper roller knobs back and forth. But take NOTE: Turn Off the power in doing so, it may destroy the knob. Have a nice day.
Best regards,
Rosener Guyano
Feb 02, 2008 | Epson DFX-9000 Matrix Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother HL-2070N Laser Printer Logo
1,215 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
