Question about Kyocera Copystar CS-1820 Black and White Copier
Waste toner full and now message error occured C7980 call service person
  • 113 Answers
Remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Posted on Nov 29, 2010
C7980
waste toner is full,,emptying it will get rid of the code!
Jan 29, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
Error occured call service person C7990
What to do if the current display is "Machine Failure Call Service C7990" but few days ago it displays "Toner Waste Box is Full".?
May 23, 2012 | Kyocera Copystar CS-1820 Black and White...
Error code C7980
This code relate to the waste toner sensor, which means your waste toner tank is full, what you can do is, take out the imaging unit(is the unit where the toner sit) look at the lower sides, there is screw from each side, take off the screw and dump the waste toner out.(use plastic bag because it is going to be a mess if you do not use one. If you do not want to go through all this procedure just order the imaging unit and replace it.
Dec 13, 2011 | Kyocera Copystar CS-1820 Black and White...
Error occurred. call service person c7980 printer
try unpluging it(the power and the usb), count to 15 and plug back in
Jan 25, 2011 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-1018MFP photo copier. Our copier has an error message C7980 which we understand means that the toner waste container needs emptying. Is there an easy way of carrying out this operation?
remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Oct 05, 2010 | Kyocera KM-1505 Copier
The printer shows "Call service person" C7980. What is the problem and how can it be corrected?
this a drum unit related problem. empty the waste toner and the error will reset automatically
Aug 27, 2010 | Kyocera Copystar CS-1820 Black and White...
What is code c7980 waste toner is full???
C7980, Defective waste toner sensor or engine board. Try this, shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be soved, replace the process unit. After replacing the proces sunit, turn the power switch off then on. If the problem cannot be solved, replace the waste toner sensor or the engine board.
Aug 03, 2009 | Kyocera Copystar CS-1820 Black and White...
Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Dec 05, 2008 | Copystar CS-1820 Copier
Kyocera Copystar CS-1820 Black and White Copier Logo
599 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
