Question about Kenmore Elite 45986 Front Load Washer
Need to replace door locking mechanics. Door came open during a out of balance load. Now can not get the door to shut. Believe it is the mechanical door locking part. How do I get the front of machine off to access the part.
  • rthatcher266 Oct 05, 2010
    This should do the trick, thanks for the help....
  • Kenmore Master
  • 19,396 Answers
Hi.
Here approximate repair procedure.
Disconnect power cord or trip circuit breaker.
Undo the two srews at the back of the machine to release the top cover.
Remove the top cover, ensure that you do not hurt yourself with metal parts.
Reach the door latch and undo the two screws holding the door latch.
Reach the latch with you hand , disconnect wiring harness and remove the latch.
Do operations in reverse order
To get part and diagrams click here and enter the full model number as printed in the service tag.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 05, 2010
I have a small older bosch front load washer that after 3 loads ,when the door isclosed the water does not come on
I never had a front load washer but I have changed several lid switch. When the door is not closed on a top load washer a switch in the door area will shut the washer down. I did run across this on a search of front load washer..
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the door lock is defective, the washer door will not latch properly. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
I saw in another post sometime the switch is under rubber
but I am just repeating what someone else said. Hope can be of some help.
Aug 12, 2017 | Bosch Washing Machines
During spin cycle, load was out of balance, now cant get the door to close. Lock mechanism is closed. How do I get the lock mechanism to open and allow the door to shut?
You can attempt to reset the operating system of your washing machine by unplugging it from the outlet and leaving it for a few minutes and then replugging it.
Dec 28, 2010 | Kenmore HE2 Plus Front Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
I believe I need a new timer
I think you are correct on this.
Jul 27, 2009 | GE WSXH208A Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
GE JGBP80 oven shuts off and the locked door light flashes
That's awesome! I just found this site on Christmas day minutes away from family arriving and I had exhausted the manual for help. Under the troubleshooting section of the manual it lists "door Locked" light blinking as a problem with the only solution being - "shut the door." With three dishes in the oven that didn't help!
I took the advice of the site and wiggled the actual door lock on the inside of the oven and that didn't work right away either.
I had to trick the oven into thinking the door was shut by pressing the sensor on the right hand side in and then turn on the oven cleaning cycle with the sensor held down. After the lock activated and moved across with the door open, I had to hold down the door unlock feature and wiggle the lock as it unlocked. A little more complicated, but none the less it worked!
It must be a sensor inside the locking mechanism that isn't reading the lock being open - or something...
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
KENMORE HE4T STARTED AS BALANCE AND F11 NOW ITS F06
ck all the connectors to both boards and motor you may have inadverantly left 1 loose or knocked one off during previous repair
Aug 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
108 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
