Question about Solar Ingraham 20 Program Electronic Timer W/random Switching
OUTSIDE FLOOD LIGHTS HAVE BEEN ON FOR 2 DAYS. IS THE SOLAR CELL TIMER BROKEN? HOW DO I TURN LIGHTS OFF?
I cannot find a manual on this timer.
If I was at your house, I would try the following:
1) Read the manual troubleshooting section
2) Check for dirt over the sensor
3) Turn off the circuit breaker to timer/ or unplug from wall
4) Re-power timer and then Re-program timer
5) If these steps don't work, the timer may have gone bad
And lastly, since many people do not have the manual, press it flat in a book for two days, scan it just like you scan a photograph or have Office Depot scan it onto a disk. Load photo of manual onto Imgur or Flikr photo-sharing and then post that link in a fixya question so others can see the manual
Posted on Oct 06, 2010
My PARAGON TIMER 4011-00PC OUTDOOR RAINPROOF is making loud noises, not sure why, started in the middle of the night
If it is an electromechanical timer, the drive motor probably is failing. Disconnect it from the power source.
Feb 02, 2015 | Paragon Hardware & Accessories
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
Will solar garden lights set off the parkhurst 400w floodlight
The should not. Motion detectors are not affected by lights other than having sufficient ambient light to the photocell to tell the light that it does not need to come on. I have not seen solar lights that fit that bill, so I would conclude that there would be no effect. Solar garden lights do not affect the flood light that my neighbors have, by the way.
I hope this is helpful to you.
Aug 10, 2011 | Garden
Trying to install Swylite LST200 for front porch lights. Switch controls 3 lights, 3 CFL and 1 regular. Home wiring is not colored, one is a ground. Have attached wires and have display on unit, but...
Swilight LST200 is suitable for incandescent and CFL
http://www.amazon.com/Swylite-LST200-W-Event-Digital-Switch/dp/B0018G4M40
Timer requires separate voltage to operate clock, just like alarm clock needs to be plugged in.
Open following link to see wiring instructions and image:
http://waterheatertimer.org/Programmable.html#wire
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 20, 2011 | Solar White Swylite Lst200 Dual Event...
I have a double switch box controlling inside lights and outside lights. I installed a GE Smart Digital Timer (model 15086) to control the outside lights. In the wall box, the white wires are tied together...
From the description you gave on your post , sounds like you hooked the timer up correctly . Again , from the panel the hot ( black ) is jointed with the blacks feeding the inside switch and the timer correct ? And the Neutral ( white ) is jointed feeding the inside lights and timer for outside correct ? And from the timer ( GE model 15086 ) the Red Wire ( Switch Leg from timer ) is connected to the Black ( Switch Leg ) feeding the outside lights correct ? If this is exactly how you've wired your timer , then you have done your homework . Now all you need to do is make sure you have programed your timer correctly , and with your instructions that came with the timer , this should be no problem . If you continue to experience trouble , my suggestion would be to return the timer . It's not unheard of for some of these timers to come from the factory defective . This wiring configuration should not affect your inside lights . I hope this helps your home wiring project . I'm an electrician if that's any consolation !
Feb 09, 2011 | Hammering
We purchased Westek photo cells for our 60 watt outdoor lighting for dusk to dawn. We have them installed tonight with the plastic cover with the smallest center hole in it. They just keep going on and...
It sounds like you are getting feedback from the lights.
Timer has a photocell, and when it hets dark, the timer turns ON.
But the lights are causing photocell to think it's dawn, so timer turns OFF.
Moment later, photocell thinks it's dark, so lights turn ON again.
And your lights blink on-off.
Passing cars lights can cause timer to do same thing.
To test timer, put black tape over photoeye.
If lights still blink afterward, then timer is defective.
To solve problem, put obstruction between lights and photocell, or tun photocell toward dark area.
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone while you solve the problem.
Jan 02, 2011 | Solar Photo Cell Digital Timer By Dib...
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How do i set my Hager time for outside lights for block of units. It has a dial. The instructions are not clear at all.
I am looking at the 31575 7-day timer manual
1) Set current day and time
The timer dial has numbers 1 thru 7 with oval circles around these numbers
1=Monday
2=Tuesday
3=Wednesday
7=Sunday
The oval numbers are located at 12 noon on each day
Since these numbers are circled with an oval, let's call them oval-1 oval-2 oval-3
Current time is always lined up with black triangle at top of dial
Right now it's Tuesday about 2am
Rotate dial until pointer is near oval-2 ... and then line up pointer with small number 2 (for 2am)
If it was 4pm, you would line up with 16 (using the European 24 hour clock)
If it was 8pm, you would line up with 20
2) Set your on-off times
The dial has segments around outer edge
Segments pushed-in = Timer ON
Segments out = Timer OFF
If you want the timer turned on for 2 days, you push-in the segments between those days
For example you want timer to turn on at 6 pm Tuesday and stay on until 3pm Wednesday
Push in all segments between those times.
Tuesday is located at the oval-2 ... 6pm Tuesday is at the 16
Wednesday is located at oval-3 ... 3pm Wednesday is is at the 15
So push-in all the segments between those two times, and the timer will turn ON at the scheduled time each week.
If you want the timer to turn on and off each day at same time, then you push in the same segments for each day.
For example the timer turns on your outdoor lights at 7PM and turns off at 11PM
Select a day: push-in segments between 19 and 23
Repeat the same for each of the other days and timer will follow same schedule each week
If you need more help, answer back and I will give words of encouragement.
Oct 26, 2010 | Hardware & Accessories
My 2008 gsxr 600 has no power when I turn the key
could well be the battery has just gone flat starting the engine up and running it for a fuw minuets knocks more out the battery that you put in and batterys dont like cold weather any how if your going to leave the bike standing around not being driven go out and buy yourself a 12 volt 2.5watt solar charger hook this to the battery and it will keep the battery toped up even in dull weather,,,,i have them on my bikes all year round,cheap power!!!
Feb 05, 2010 | 2008 Suzuki GSX-R 600
Solar Ingraham 20 Program Electronic Timer W/random Switching Logo
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
