I have an old Phillips Magnavox television. I turned it off and, as usual, the screen took a while to completely stop glowing (vaguely white glow). As it was almost black, suddenly there was a flare of light in a circle-like shape that grew and then faded away. This bright light was like looking at thick vertical bars of primary colors through a cut out circle and was as bright as colors would ne if the tv was on. Does anyone know what this is? Is this a fire hazard?
    President:
  • 1,779 Answers
Techman(solution #2) is correct on your problem. #1There had better be no air in a crt.that statement should be discarded by all means. If you drop down your contrast level the phosferous in the crt will not glow as warm thus reducing after-glow. Hope this answers your question.
Posted on May 29, 2008
    President:
  • 1,284 Answers
And to top that off, that means your CRT in your TV is better than average. It means that the CRT has less air in it than most causing the slow discharging of high voltage. RCA and most companies call this "afterglow" and in some cases the CRT will also do a "preglow" when you first power it up.
    President:
  • 3,130 Answers
No that is a normal situation, as it is the high voltage bleeding out of the picture tube. You will normally only see this happen in a darkened room. I would not worry about it.
White glow around dark objects
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Philips 55PW9383 55" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
"Halo" Effect
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 19, 2009 | Philips Magnavox 55P9271 55" Rear...
I have a magnavox rear projection tv and anything white on the screen seems to have a glow to it
i had the same with my Magnovox....had the fluids changes and cleared it up....even cleaned up the focus of the picture...although this will cost somewhere around 300 bucks..
Dec 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60
It's probably the magnets on the neck of each CRT that moved since you removed them or the CRTs weren't put back in the exact orientation . Use a white paint pen to mark each one as they are now. If there's a clamp or two metal rings that locks them in place you can try rotating them as a group (their location up and down the neck is also critical).  If not you will have to adjust them individually and then do a complete convergence adjustment. That's a big task. Good luck.
Sep 28, 2008 | Philips Magnavox 51MP392H Rear Projection...
Convergence issues...green glow around objects on the screen
a green glow sounds more like a coolant issue more than convergence. Is your TV a phillips or magnavox by any chance? Please reply to this same post and let me know your model number.
Jul 28, 2008 | Televison & Video
Extreme White Glowing
Your CRT fluid needs to be replaced. Goto www.TvRepairKits.com and order their fluid kit.
Sep 28, 2007 | Philips 60PP9363 60" Rear Projection...
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
