Hello...Our IMAGECLASS D880 won't copy and it has Error E003
  • 185 Answers
It is probably a bad fuser FG6-7947-000. This isn't user installable so you will need to get a technician for this.
Whit
Item, Inc.
Posted on Oct 06, 2010
What is system error E003?
you need to Fix heater assy. low temperature. You need to replace the assy.
Feb 07, 2011 | Canon imageCLASS D880 All-In-One Laser...
I have error code E003, can I fix this myself?
MENU and #, clear err and ok.
If doesnt help replace fixing unit
May 04, 2010 | Canon ImageClass D880 Copier
System error E000 cannon imageclass D860 copier will not operate even after turning the power off overnight
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300/1310,1330,1370,1630,1670, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681/D880
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
i hope this will work if not then
if You are not out of warranty, this unit has a three year warranty.
The machine was introduced in September 2004.
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer
best of luck
Oct 29, 2009 | Canon imageCLASS D860 All-In-One Laser...
System error e000
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Which relates to the fuser temp. you need to change the fuser unit.
Sep 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
We got erro E000
E000
it all relates to fuser temp. change the fuser unit.
Sep 29, 2009 | Canon imageCLASS D880 All-In-One Laser...
I just received an E003 error when running my Image Class 860 copier. Any suggestions? Thank you so much!!!
Please clean the fuser unit thermistors and thermofuses and verify the continuity the fuser heater lamp.
Sep 28, 2009 | Canon ImageClass D880 Copier
Error E000
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon ImageClass D880 Copier
Falla cannon
Hope that helps...
Lbcoaster
Jul 11, 2008 | Canon ImageClass D880 Copier
Error message on printer E000
E000 is a fixing unit problem. It could just be needing to be reset or replacement of the fixing unit or if that is not the fix it may coast more then it is worth.
Jun 11, 2008 | Canon ImageClass D880 Copier
Canon ImageClassD880
This error has to do with the Fixing (fuser) unit. The fuser is located in the paper exit area. Try this first, turn the machine off for at least 10 minutes. If that doesn't work, you would have to be a technician or have a technician fix this problem. It is very involved to replace this part.
Jul 31, 2007 | Canon imageCLASS D880 All-In-One Laser...
k24674
jasbo
jasbo
