Question about Pitney Bowes Office Equipment & Supplies
How do i clear error code 77 on an imagistics 1500 fax machine?
checkitright
  • 1362 Answers
SOURCE: error code fax
check this link and go to error codes/fax error
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Nov 27, 2007
bowdo
  • 78 Answers
SOURCE: brother fax machine intellifax 2600
Fuser or overheat error it will probably be followed by a 77. Menu, mode and 0 quickly in that order will give access to user maintenace mode (lights will flash once your into the mode). Hit 91 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
Posted on Feb 07, 2008
SOURCE: imagistics 2500 fax stuck in the "printing" mode. Need to reset.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Posted on Aug 06, 2008
SOURCE: Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Posted on Sep 08, 2009
  • 567 Answers
SOURCE: Machine error 77
Hello there, in a situation like this the best thing for you to do is to call Brother customer service at 800-284-4329 and explain the problem.
Thank you
Posted on Jul 17, 2010
My imagistics c235 has a red wrench light on. Does anyone now how to clear this?
The red wrench indicates a serious problem. Does it show any error codes ?
Mar 05, 2011 | Office Equipment & Supplies
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
Error 77
Error 77 is fuser error . Shut off the power for 20 minutes . If that didn't reset the unit , then you need a new part . Call the local dealer to ask about new part price .
please rate !
Apr 13, 2010 | Brother IntelliFAX 2800 Laser Fax
What is "error 77"
Hello.
Error 77 indicates a reset condition.
I'd suggest to open the front panel, remove the toner and close the front panel. The printer will try to warm up and then display to open the panel door. Open the door, insert the toner, close the panel and the machine error should clear.
Hope this helps.
Jan 29, 2010 | Brother Office Equipment & Supplies
I have an error that indicates paper jam, open-- imagistics 2500
Check the paper trays sensor,and describe detailated the your problem and please tell me the fax machine models for more help and information.
Sep 17, 2009 | Office Equipment & Supplies
Brother fax machine intellifax 2600
Feb 07, 2008 | Brother IntelliFAX 2600 Fax
Problems with the fax machine
YOU CAN TRY A SYSTEM CLEAR BUT IT MOST LIKELY NEEDS A FUSER UNIT
SYSTEM CLEAR  MENU *2864 THEN 01 THEN 99 TO EXIT
Aug 31, 2007 | Brother IntelliFAX 4100 Laser Fax
125 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
