Question about Swintec 7040 Typewriter
How do I set the margins on my Swintec 2416DM typewriter? Also, how do I change impressions control?
  • Swintec Master
  • 3,594 Answers
Go to the margin you wish to change, touch don't hold the MAR REL key, space or backspace to the desired location, press R. or L. margin key.
I believe the impression control is a slide switch on the L. side of the keyboard.
DickyO
Posted on Oct 05, 2010
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
What do I press to set my left and right margin on the swintec typewriter 7040
Go to the margin you wish to change, PRESS BUT DON'T HOLD the MAR REL key space or backspace to the desired location press L. or R. mar key.
DickyO
Feb 18, 2012 | Swintec 7040 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
I have just started using an old swintec 8016 select series typewriter and do not know how to release and set margins
I believe you go to the margin you want to change, touch don't hold the mar. rel. key (top L. of keyboard) then space or backspace to the desired location, press L. of R. margin key on the L. side of the keyboard.
DickyO
Aug 12, 2009 | Swintec Office Equipment & Supplies
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
Margins will not hold, have to keep resetting them.
Auto margins are permanently stored in the Swintec 8014S. If you set new margins within those margins, they should hold. If you set them outside of the auto margins you will have to use the MAR REL key to release the auto margins, and then set the new margins. All margins are set by pressing the Left or Right Margin Set keys.
These settings are stored in a memory circuit that is powered by a battery that is automatically charged when the typewriter power is on. If you still have trouble with the margins releasing after you turn off the machine, you can try one of the following:
(1) Keep your typewriter on for a couple of hours so the battery can recharge and then save your margin settings
(2) Replace the battery which may have died after all these years. You would need to bring your Swintec to a local dealer for the part and replacement service.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 06, 2009 | Swintec Office Equipment & Supplies
Swintec 2000 Margin
You should reset the margins where you would like them. To do this, go the the file screen and press MARGIN. Press <--- to change the left margin, or ---> to change the right margin, or the up arrow to change the top margin, or the down arrow to change the bottom margin.
Do one at a time. When you choose one (i.e. <---), the message "LEFT MARGIN SETTING" appears on the screen and the cursor moves to the left margin column automatically. Move the cursor to the desired location by using the arrow keys. As you move the cursor, the corresponding margin mark moves along with it. The press "DO" to set the new margin.
Hope this helps.
Aug 26, 2008 | Swintec 7040 Typewriter
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
170 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
