Question about Lanzar VIBE266 Car Audio Amplifier
So i hooked up the amp useing the pre-existing 8 gauge wire with a 30 amp fuse it worked for about and hour and started blowing the 30 amp line fuse. i replaced the line from 8 to 4 gauge and installed an 80 amp line fuse. this worked for about an hour and now it is blowing the 20 amp fuse on the amp. Any ideas?
    Problem Solver:
  • 11 Answers
This sound like a case of arcing power wire it happens very very easy if u use cheap wire especially from walmart. whatever u do keep using fuses and get a batt test asap. if u take out the fuses ull burn the amp like no other and plobably burn out the power rails which will be cheaper to buy a new amp after that
Posted on Oct 12, 2010
I'm running 8 gauge wire for battery cable and ground cable....my amp.is a momentum 600 watt...2 channel. ....my fuse is blowing every time I hook up either cable...
First of all, what size fuse? Check the amp and see what max amperage is, and insure your fuse is that size. Secondly, I suspect either a blown speaker or blown outputs. Disconnect the speakers from the amp and see if the fuse still blows. If it does, either you are hooking two wires up improperly, or your outputs are toast.
Aug 06, 2016 | Car Audio & Video
Why do fuses blow
overload will blow you fuses.short to ground. wtich fuse is blowing?
Apr 16, 2014 | 1998 Acura TL
Have a hartke lh1000 head . played about 5 total hours then blew the fuse. is this something i shoud be worried about?
If the fuse is correct ( check manual) it shouldn't blow under normal operation. Once in while a fuse will break internally and thus blow the fuse. look close at the blown fuse If it is a "violent" blow (totally black inside) then you have an overload condition. I would use an ohm meter to check the connection to the speakers. Usually it should be between 8 ohms and 4 ohms if the number is lower than 4 ohms your speakers or wiring are putting to much of a load on the amp. If the fuse was not a "violent" blown fuse then replace with a new fuse of the exact proper value. many amps use an MDL fuse that is a slow blow fuse and has much different in circuit function than a ACG fuse so use only the exact proper furse that the manufacture recomends. If the load (speaker and wiring) is correct and the fuse is correct and still blows then you have a component problem and the amp will need repair
Jan 19, 2012 | Hartke Lh1000 Bass Amp Head 1100 Watts...
Need to hook 230 volts to car lift
this is 2 ---110 volt power feed lines & a neutral ( ground ) 3 wires all together , a second redundent ground won't hurt -----the same power feed as a stove or dryer .make sure to use at least 10 -- 8 gauge stranded wire / check the product requirements ---thicker wire ( smaller gauge number ) for more amprage or loner distance...will also need two 15--30 amp circuit breakers///// check specs......
May 26, 2011 | Air Tools & Compressors
1984 Chevy 350 has two fusible links,one foe ignition the other for headlights which is blown. Can I replace with a blade fuse and what amperage is equal to the wire gauge that is on the original?
Fusible links work much differently than blade fuses, they can tolerate a large load without melting, this is why they are used for high amp draw systems. You can't substitute the blade fuses, they will blow repeatedly if you do. Fusible links are very cheap and all auto parts stores have them, they go by color to indicate what the amp rating is, wire gauge is not used. So the bottom line hear is you can use blade fuses but they will likely blow often, you will need fusible links (Green) or 30 or 20 amp fuses. Here is the color breakdown of all fusible links.
BLACK 45A
RED 35A
GREEN 30A
BROWN 20A
May 24, 2011 | 1984 Chevrolet K1500
I installed a planet audio TW402 amp in my car. i put this amp last summer. when i first put it in my car with an sony xplod sub. i had a very small 12 gauge power wire and ground wire. but still it worked...
It could have to do with how your speakers are wired. If you have 2- 4 ohm speakers and they
are both wired to one terminal (RIGHT OR LEFT) on the amp, you have a 2 ohm load and most amps are rated at 4 ohms.
Go to this site and use #58 on the right sidebar to see if you are wired correctly.
http://www.bcae1.com/
Mar 14, 2011 | Planet Audio TQ402 Car Amp
Need a wiring diagram for a american pro 1406
Very simple :
12V+ = Red 8 Gauge Wire to positive battery terminal with a 30 Amp fuse
Ground = Black 8 Gauge wire to non painted surface on chassis of car.
Remote Turn on = Blue / white thin wire from radio's blue/white , this will turn on your amp.
A set of RCA cables which are self explanatory. Out to In or In to Out
Radio to Amp under carpet to back of vehicle along with your blue wire.
Then you have your speaker wires, you hook these up to your subwoofers.
Hope this helps, good luck.
Lex..
May 21, 2010 | American Pro VS1406 Car Audio Amplifier
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Lanzar VIBE266 Car Audio Amplifier Logo
102 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
