Question about Premier Watts 500528 Four-Chamber Tankless Electric Hot Water Heater
I need the elements for water heaters premier
    Problem Solver:
  • 6 Answers
Call the manufacter direct, they will usually have the part that you need. Be very careful of the plastic container hold the element inside. The break very easily, then you will have to replace the whole tank
Posted on Oct 06, 2010
Why do I suddenly have no hot water in my electric Premier Plus water heater?
1st check the circuit breaker that supplies power to the water heater. If that is OK then check and see if you have power to the heating elements on the water heater. If not then check and see if the thermostat on the water heater has power to its connections and verify that it is calling for the water to be heated. Last if all these checks are OK then you must have a burnt out heating element. Some can be replaced but you will have to drain the water from the heater before replacing the elements.
Feb 22, 2015 | Water Water Heaters
Need wiring installlatison
How to wire tankless electric water heater. Reading required.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Add a comment and describe more detail, including product and number of terminals, including information shown on product label.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 20, 2013 | Watts Premier 500528 Premier Four-Chamber...
I need to find the heater elements for a vanguard water heater 240v 36 kw model 6e746a
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) March 2013: Add a comment and describe the water heater and the element.
Mar 12, 2013 | Water Heaters
Ow do i test heating element on rheem water heater
1) Copy following link for 3-step testing water heater elements.
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) You need $10-15 multimeter from local hardware
Dec 11, 2012 | Eemax EX1440SP Heating Element for SP3208...
Premier Plus Model#MHE62-30H-045DV Ser#45T421608 I just purchased this hot water heater.I had it professionally installed by a plumber.We had hot water before I went to bed but when I woke in the morning...
sounds like you have a power problem. or worst than that a leak . So lets look at the leak first. Turn off the water supply at the water heater on top. This valve should be on the cold side of the heater on top.
Turn it off, check and see if you have pressure in the house by turning on a faucet. It should run for a second then stop. That is good if it does. Leave the valve off on the heater and check that your breaker is on. Reset the breaker by turning it on and off.
Wait about 2 hours turn the heater back on and check to see how hot the water is hot then you might have a leak in the building. If there is not or little hot water. Check the wires where it connects to the water heater. You might only have one wire that is connected right.
The best thing to do is to get a amo meter and check to see if you have 220 if you dont have 220 you will not warm up the water the way it should.
Thanks Richard
Sep 07, 2011 | Premier Water Heaters
I have an eighty gallon tank and can only get two quick showers out of it. I pull the relief valve open and got hot water. then i opened the drain valve at the bottom and got cold water. does this mean the...
Suspects are lower element -or- either upper or lower thermostat.
If water heater has some hot water, then upper element is good, and electricity and circuit breaker to water heater are good.
Dual element tank is 240Volts.
Good news is tank-type electric water heater is fully repairable by homeowner using generic parts from hardware or home center:
Links below explain water heater repairs with step-by-step photos
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Premier Water Heaters
No hot water
what kind of heater ? if its gas the premier has a thermocouple that is kinda hard to get your hands on,almost need to go to the dealer for parts.
Jan 07, 2011 | Premier Water Heaters
How do I change the heating element on my 50 gallon electric Reliance 501 hot water heater? Where can I get the heating elements?
Buy elements at local hardware store or home center, like Lowes
Look at label on side of tank.
Label shows element wattage.
Element is also printed on end of element in tiny letters-numbers.
Typical elements are 4500 and 5500 watts.
Tank needs 10 gauge wire and 30 amp breaker for 5500 watt element.
Water heaters are fully repairable by homeowner.
1) Have you tested water heater to see if element is problem? You need cheap multi-meter from Home Depot.
2) To change element
a) turn off power
b) drain water from drain valve ... once it starts draining, loosen element slightly while tank still has weight to hold against you turning element wrench.
Here's what to do if water heater won't drain:
http://waterheatertimer.org/Water-heater-will-not-drain.html
c) open covers on tank, remove element using element-wrench from hardware store or home center.
If element won't come out:
http://waterheatertimer.org/How-to-remove-old-water-heater-element.html
d) Clean out tank if needed.
e) Replace element.
f) Fill tank entirely with water before turning on power or element will burn out.
g) Once tank is filled, and water flows steady out of tub spout, turn on power.
Each steps above is shown on following link:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) You need to buy some things:
Screw-in type (not bolt-in type) Element that matches wattage on tank label. New Element comes with washer.
Inexpensive Element wrench.
Inexpensive multimeter if you are going to test parts first.
Some pieces of pipe and hose if tank sediment needs to be cleaned out.
Washing machine hose if tank will not drain (return after job is done).
4) Also:
You need flat tip and phillips screwdriver.
Lighting to work on tank
Some WD-40 if element is stuck in place.
Garden hose to drain tank.
Shop vac and duct tape if you need to vacuum out sediment.
Tarp to protect floor and carpet
Maybe a knife to cut back insulation on wire if wire is burned at element.
Web links above go through entire process step by step.
Add a comment if you need more help, I'll be back around 5 CST
Nov 30, 2010 | RELIANCE ELECTRIC WATER HEATER
I need the elements for the water heater premier model # pth28t2t 150psi max
I am also looking for replacement elements for a aquasota model PTH28T2T
Oct 05, 2010 | Premier Watts Two-Chamber Tankless...
Premier Watts 500528  Four-Chamber Tankless Electric Hot Water Heater Logo
66 people viewed this question
Top Premier Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Premier Water Heater Expert? Answer questions, earn points and help others
