Question about Garmin StreetPilot C330 GPS Receiver
My garmin will not start up at all. Tried the reset button but to no avai.l
  • 2 more comments
  • jcekkens Oct 05, 2010
    No. The light is on at the plug in but nothing at the gps.
    I already tried the reset 3 times but it acts like there is no power. As I said before, the green light comes on at the plug-in but nothing at the unit.
    I tried it as you suggested. But nothing. We were just driving down the highway and it stopped working.
    Thanks for trying. We will take it back to Best Buy even though we bought it in 2006.
  • Garmin Master
  • 6,993 Answers
if your gps acts like there is no power, then it having a power problem. The first thing to check is the battery.
You can test the gps with another battery and see if it will power up.
Good luck.
Posted on Oct 06, 2010
  • Garmin Master
  • 13,433 Answers
Does the unit react when plugged into a charger?
Posted on Oct 05, 2010
  • 2 more comments
  • Ekse Oct 05, 2010
    Does the unit respond to being reset?
    see how reset below:
  • Ekse Oct 05, 2010
    I'm sorry, you had tried the reset button already.
    How about if you reset it while its plugged in the charger any change? how about without charger?
    Do you have any idea what might have caused the unit to ""Die""?
  • Ekse Oct 05, 2010
    Sorry it seems like a major hardware problem, I can't say what is wrong with it without taking it apart. Not even sure if I could find out, You could check the battery inside, use a multimeter to check the voltage, see if there is voltage from the power plug. And that it matches the voltage mentioned on the adapters label.
  • Ekse Oct 05, 2010
    The unit is most likely outside of warranty as these are not being made anymore?
    -- very difficult to say over the internet what could be wrong with it, it needs repairs in any case, not a simple thing at this point.
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
My Edge 305s GPS is not working. Everything else runs perfectly fine, it just will not acquire any satellites. I tried a soft reset. It won't let me hard reset though.
Hard reset is not very easy, so follow carefully instructions above.
Now simple advice, did you check in your parameters that the GPS transceiver is turned on ?
There is a mode with GPS off, don't ask why ...
Refer to your manual to find the menu.
Nov 22, 2010 | Garmin Edge 305 GPS Receiver
Garmin edge 705 will not turn on
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
Garmin Edge 705 Frozen
Only hard reset cleans up memory, when corrupted.
Hold Mode and Start buttons for 10 seconds (device off). Then without releasing pulse press lap/reset button, you'll get a screen for confirmation, all data lost, including user data and routes.
May 14, 2010 | Garmin Edge 705 Handheld GPS Receiver
My Garmin says no detailed maps found that support routing? It will not go away and the reset I tried didn't work. ???
Did you try a Hard Reset, or just push the button on the bottom of your Garmin Nuvi 205?
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Jan 30, 2010 | Garmin nuvi 205 GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin is frozen on, and will not respond.
Have you tried resetting the unit? Remove the faceplate and press the reset button on the right side of the unit. This may help.
Feb 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
27 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
