Question about E-Machines eMachines Desktop PC
When I turn my emachies laptop on it shows the logo then goes to a blank screen I can access setup menu but it won't boot up help it's the64bit version I beleave I've tried everything I know I think the hard drive maybe locked out??
  • 707 Answers
Bring up task manager (Ctrl+Alt+Delete)
click applications tab
click new task
type in explorer.exe then click okay
If it boots up go to www.malwarebytes.org and download the free version. Install, update, and run a full scan.
Delete anything it finds.
Sometimes this works, sometimes it doesn't.
Good luck
Posted on Oct 29, 2010
How can i access to the boot menu with fast boot activated?
try repeatedly pressing esc button or failing that repeatedly press f2 button on boot up
Jul 11, 2014 | Toshiba Satellite 15.6" P755D-S5378...
My System Fujitsu Siemens Scaleo P cannot boot windows and doesn't proceed after display of Fujitsu Siemens Logo (Where it says Press F2 to Enter Setup).
I would take it back to the place of purchase, it is clear the window installation was not completed, a manufacture oversight.
Jun 18, 2012 | Fujitsu LifeBook AH531
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
My laptop is not loading anything only it show toshiba logo then it goes blank screen i cant acces boot menu by pressing f12 i cant access bios setup menu by f2 when i press these it only show entering...
I would contact www.toshiba.com amd speak to the technical department, they are very helpfull. It may be a RAM fault or a hard drive fault but as you have data on the drive, I don't want it to go pear shaped and for you to lose any data.
Hope that helps.
Mar 09, 2011 | Toshiba Portege M800 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
ACER ASPIRE 9410-4933 LAPTOP SCREEN GOES BLANK DURING P.O.S.T.
Were you working with laptop in battery mode, not plugged in a/c power? You could have drained your internal DC battery & at the same time damaged your B.I.O.S. [button type] battery inside the laptop. that the computer goes into POST means that it is trying to FIND itself, not finding the graphics card, it does not know what type of 'picture' ( usually black screen with ""DOS"" words ) to show you.
1st- turn laptop on, you should see name,what type of cpu (the "inner " workings of computer) and sometimes the amount of memory (clicking like a digital timer) If not, don't worry. Press f1,or DELETE, ESCAPE (ESC), or read your book to find the KEY to puts you into SETUP. There should be a menu and somewhere there are DEFAULT. USE THOSE! Reboot to see results.
Apr 02, 2009 | Acer Aspire 9410 Notebook
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
