Question about Samsung ML-2510 Laser Printer
Samsung ML-2510 is connected to a Dell Optiflex GS 280 computer. I get message "Fuser Open Heat Error" when trying to print. Is this just a fuse on the cartridge or a more complex problem?
  • 525 Answers
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
I get a message "Fuser open heat error. I turned
The main power supply board in short we call it (SMPS) the error you got is quite common that the main power is not getting in to the transformer in the correct voltage. Normally is to replace the SMPS and the fuser as well.
For more Technical test on the SMPS 1st of all we will test the fuse on the SMPS which is located at the bottom right hand corner. using a multi-tester, 2nd will be the capacitor and 3rd which is the last will be the big and small transformer with power on. note the last test is dangeroures unless you are a electrician experts.
Best of luck!
Sep 06, 2011 | Samsung ML-2510 Laser Printer
I have dark streaks with all print-outs on a Samsung ML-2510. It goes away on a new cartridge.
This is a common problem with a close-to-empty cart.
A new cartridge will have even toner, and will distribute it evenly to the page.
An older toner will start to streak and line onto the page.
Another issue could be the fuser... some of the new printers have a fuser built into the cart unit... so that when you replace the cartridge it replaces the fuser as well.
A fuser can become dirty and thus not distribute toner evenly across the page.
Cheers!
Feb 23, 2011 | Samsung ML-2510 Laser Printer
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Samsung ML2571N Fuser Open heat error - Fuser Is Good
Hi Kevin,
hope this help :)
SamsuTech
Jan 23, 2010 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Have you found a solution to the Samsung ml-2510 printer red error light staying problem?
There are a couple of reasons why this happen. A paper jam could have occurred. The cover might be open, try closing the
cover. There might be no paper in the tray, load paper in the tray. The toner cartridge is not installed. The printer has stopped printing due to a major error (you need to contact your manufacture for this).
Nov 11, 2009 | Samsung ML-2510 Laser Printer
PRINTER NOT PRINTING ERROR MESSAGE : OPEN HEAT ERROR CYCLE POWER
This is the problem of the fuser unit. You may get it repaired/changed . Also you may approach Authorised servic ecenter.
Jul 25, 2009 | Samsung ML 4551NDR - printer - B/W - laser
CRU Fuse Error
xeregtei bna aa nadad ogooch pls
Sep 30, 2008 | Samsung ML-2510 Laser Printer
Paper jammed
Your fuser is bad. The fuser is a part that "fuses" the toner with heat and pressure to the paper. You will have to have a new fuser to fix your problem.
Jun 23, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
184 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
