Question about PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres
Shuts down i start installing windows xp and it almosts finishes when the computer shuts down. And I have to start all over. What is causing this to happen.
  • Steven Burn
    Steven Burn May 11, 2010
    Have you tried copying the I386 folder to the hard drive prior to installation?
    Is it displaying an error message?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
My suggestion is that you haven't preload any type of windows and are prombally missing files that need to load,is your pc a nt 2000 ? if so you need to load previous version of windows on it then load the xp....la la linda
Posted on Jun 02, 2008
    Problem Solver:
  • 6 Answers
Always test ram (use "memorytest86") as its a freebee and the test is exhaustive. better yet you can easily make a bootable CD thus no OS is loaded. always do this before an OS install/re-install.
as mentioned elsewhere in this thread if the OS fails to load more than likely its an obscure hardware issue. some of the anomalies I've found through the years...
ascertain that your video hardware "matches up" within the BIOS. if you have 2 CDROM drives set one set to Master (IDE) and disconnect any secondary drive. wierd thingees begin to happen on some systems if your boot drive is slave regarding an OS install.
    Problem Solver:
  • 33 Answers
Go to minimal ard ware. I have seen network cards, ram, modems,cdroms,extra hard drives, higher end video cards and miscelanious other hard ware cause it. If you are having this issue go down to minimun harware one cd, one hard drive,one stick of ram, just the on board components of *********** board. That should take care of it.
Posted on May 29, 2008
    Problem Solver:
  • 7 Answers
Change ram and try again
When my computer starts on window xp blue screen appears with fatal system error last time i will update my pc to sp3 and install . installing takes too much time i will unpluged the computer and then...
when your computer is updating do not turn off or shut down your computer this will be the reason for your windows operating system crash. just let the windows update to finish. this this type of error you will need to contact your computer manufacturer or try re-installing your windows XP. If you wish to reformat your computer make sure to back up all your files first.
Sep 10, 2011 | Intel Computers & Internet
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
How to repair system32/drivers/pci.sys w/o any CD
  1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices.Restart your computer.If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices.
  2. If Windows does not start successfully, remove one or more of the memory modules(RAM) that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Aug 29, 2010 | Intel Computers & Internet
Computer begins to start up and then turns off after windows xp is displayed. Reformatted drive installed windows 2000, same thing happens
The issue that you experience might be problem of your power supply please change the location or check the power supply of computer. If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
For more information, please click the link below;
http://support.microsoft.com/kb/320299
Moreover, check the motherboard, CMOS battery or SMPS, as that might be one of the reason. Any of such device not functioning properly may cause computer restarts automatically.
Regards,
Anirban Mazumdar
Computer & Accessories Category Expert
May 30, 2010 | E-Machines eMachines Desktop PC
It Says "Installing Updates" but never shuts down
If you are updating windows xp and it says installing updates when you are shutting down your computer, you should let it finish, even if it tales overnight. depenind on how many updates you have, better to go to the updates web site and do it from there. after they have installed then you should be able to do a restart on your computer and compleate. Any thing ells you are best off contacting MicroSoft
Aug 17, 2009 | Microsoft Windows XP Home Edition English...
Infected pc boots up intermittently
Microsoft does not "shut down" computers. If the PC is not booting every time it is because of the viruses or the power supply. If you press the power button and nothing happens I suspect the power supply. If you see the start-up screen every time you press the power button, but the computer does not finish booting go ahead and install your legal copy of Windows and that will fix the problem. Make sure you have the drivers for your motherboard, you'll need them to install things like chipset, nic, video, and sound drivers.
May 18, 2009 | ASUS P5S800-VM Motherboard
My system gets to login screen and then restart and shut down
What kind of pc are you using? This happened to me a while back and I had to do a system restore because the drivers that I updated were currupted.
Mar 14, 2009 | Microsoft Windows XP Professional
Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
http://www.ubuntu.com/
Feb 26, 2009 | Computers & Internet
Samsung v25 shutdown
hi dear
Do not complete the following procedure unless you are very familiar with internal computer hardware removal and installation. The hardware components in a computer are very sensitive to static electricity. For information about the correct handling of computer components, contact your computer manufacturer. 1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices. 2. Restart your computer. • If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices. • If Windows does not start successfully, remove one or more of the memory modules that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Note Windows XP requires 128 megabytes (MB) RAM. The minimum is 64 MB and the maximum is 4 gigabytes (GB).
For example, if two 256-MB memory modules are installed in your computer, remove one of the memory modules. If Windows starts successfully, shut down the computer, and then reinstall the RAM modules one at a time. Start Windows after the installation of each RAM module. When you install a module that causes the issue that is described in the "Symptoms" section, remove that module, and then continue to install the other RAM modules. 3. Determine if the PCI devices in your computer are compatible with Windows XP. To do this, visit the following Microsoft Hardware Compatibility List (HCL) Web site: http://www.microsoft.com/whdc/hcl/default.mspx
Mar 22, 2008 | Samsung V25 XVC 2800 Notebook
Can I use the PDC 1100 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 1100 camera. Follow the instructions below to reinstall the PhotoMAX software and camera drivers using Windows XP's Program Compatibility Wizard. 1. Insert the PhotoMAX CD-ROM in the CD drive. If the program begins installing, press OK to close the "not compatible with Windows NT" error message. 2. Start the Wizard by clicking the Start button and choosing All Programs > Accessories > Program Compatibility Wizard. Follow the on-screen prompts. 3. On the second screen, select I want to use the program in the CD-ROM Drive and click Next. 4. Select Microsoft Windows 98/Windows Me and click Next. NOTE: You may have to scroll down to see this option. 5. Uncheck the following items: * 256 colors * 640 X 480 Screen Resolution * Disable Visual Themes 6. Click Next. 7. Click Next again. The PhotoMAX software will begin installing. Follow the on-screen prompts. 8. Follow on-screen prompts to finish the installation and click Finish. 9. When the Compatibility Wizard asks if the program worked correctly select Yes and click Next. 10. When the program asks if you want to send information to Microsoft, select No and click Next to finish the installation. 11. Shut down and restart the computer. After the restart, you should be able to download photos using Windows XP.
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres Logo
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
