Question about Navman Tracker 5100i GPS Receiver
Hello I require a new power / data cable for my Navman 5100i Gps Chart Plotter . Can you please tell me where I may buy such an item Thanks David
  • 16 Answers
SOURCE: Raymarine GPS system HALT ! URGENT PROBLEM
To get back up and running you are going to have to reset the unit. This is from the handbook:
Note: Take care - factory reset clears allWaypoint and Route databases.
➤ To perform a factory reset:
1. Power off the unit.
2. Press and hold CLEARwhilst powering up until <Erase backup procedure>
is displayed.
3. Either press CLEAR to abort Factory Reset and resume normal
Power-Up or press ENTER to continue Factory Reset.
4. Press ENTER again; the unit restarts as for a first time PowerUpwith
all values reset to their original factory settings
When you hit port and have an internet connection, make sure you are running the latest software version, currently listed online as version 1.09. You can download it here:
http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=965
Posted on Dec 28, 2007
Maanita
  • 1142 Answers
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Posted on Sep 02, 2008
  • 37 Answers
SOURCE: Navman Repair
Try here www.satnavservice.com
Posted on Sep 02, 2009
  • 43 Answers
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Posted on Oct 22, 2009
  • 16 Answers
SOURCE: navman tracker 5100i keep loosing gps signal and
NAVMAN F10 WILL NOT ACQURE GPS SIGNAL EVEN AFTER RESETTING
Posted on Nov 24, 2009
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
5500 Navman no brightness selection
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (no antenna socket on i models) .
Where water has arced there will be burning black on the green PCB evident, cut the gold PCB flat wire and remove the section around the burn.
scrape a small amount of green off the gold flat PCB wire so you can solder a new wire to bypass the short. any 2.5mm insulated wire will do to bridge the gap you have just scraped away, there is plenty of room for a 1 inch wire.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
Nov 27, 2012 | Navman Tracker 5500i GPS Receiver
What memory card does the 5505 take
CLICK HERE for all the info.
CLICK HERE for the Manual.
Your specific question's answer is on page 7 of the manual:
C-MAP™ chart cards have chart details required for navigating in a particular region. When a chart card is plugged in, the extra details automatically appear on the TRACKER chart display.
The TRACKER can use NT, NT+ and NT-MAX cards.
C-MAP™ user cards are used to store navigation data. Each user card expands the TRACKER memory and allows the data to be transferred to another TRACKER easily (see section 14).
Note: The older 5 volt user cards are not supported.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2010 | Navman TRACKER 5505 GPS Receiver
Sep 27, 2009 | Raymarine A65 Combo GPS...
Navman 5500 gps backlight dim but set to max
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
Navman Tracker 5100i GPS Receiver Logo
167 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
