Question about Moen Plumbing
I have a Moen Two Handle Bath Tub Set (I think is the MontiCello Modle) the right handle does not stop at the close position and revolves 360 degree when turned. I have to find the appropirate position that results in the least amount of water escaping at the faucit. The handle has a slightly cracked plastic ridged sleave which goes into the handle. How do I get a replacement part?
  • 333 Answers
You can get a replacement cartridge at any hardware store, such as Lowe's, Home Depot, True Value etc... You just have to know the name brand and type. But sounds like it is just the knob broken. You could get two knobs that match if you can't get one exact.
Posted on Oct 05, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Metal handle adapter for single handle shower monticello cannot remove it
    Did you remove the Philips screw that holds it in place? If you have and still can't get the adapter off try heating gently with a torch.
    Feb 16, 2014 | Moen T3129 Chrome Monticello Single Handle...
    Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
    You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
    You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
    You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
    I hope this helps.
    Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen monticello shower control, remove handle
    If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
    Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    Turn hot handle on - water does not come out of faucet
    is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
    Sep 26, 2009 | Moen 4551___ Monticello Popular Two Handle...
    Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
    Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
    Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
    Moen Model no. 82683 does not close
    It sounds like the handle needs to be replaced. the stop place is in the handle. You can
    Aug 30, 2009 | Moen & One Handle Tub & Shower Faucet
    How to remove the handle of a monticello 4551 moen faucet. I need to access the cartridge. After screwing the brass stem out, does the chrome ell shaped cap rotate to unscrew or is there a set screw I...
    grab bottom of handle,(the fat part of handle closes to faucet body) and grip hard and turn counter clockwise to get to cartridge. dont use channel locks pliers or you risk damage to finish. can be done by hand and very tight grip
    Jun 23, 2009 | Moen 4551___ Monticello Popular Two Handle...
    Plumbing Logo
    81 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
