Question about Panasonic NN-L531WF Microwave Oven
I have a Panasonic microwave oven NN-L531WF. Countertop, 1100 Watts. It's 8 years old. Used about 5 times a day to heat water for a cup of coffee (60 seconds). Problem: All of a sudden, it runs only 3 seconds, then stops and goes back to zero (0). This happens with any time punched in, 1 minute or 2; 40 seconds; 15 seconds. It starts OK, but stops every time after 3 seconds. Questions: (1) What causes this? (2) Is it worth to pay lots of $$$ to have it repaired, or should I just throw it away and get a new one? Thanks for any useful suggestion. -- Rey
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: start but shut off after
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Countertop light will not go off on Panasonic NN-P294SF
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
SOURCE: Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Posted on Nov 24, 2010
How to make pizza in nn-s215mf
Problem with pizza in a MICROWAVE is the
mass of the pizza is not adequate to absorb the
radiation... Energy is returned to the ($50)
MAGNETRON significantly shortening the
LIFE-CYCLE of the OVEN.
If you must warm a slice of pizza or a pat of butter
you will be big $$$$ ahead adding a cup of water and
boiling water at the same time...
Have a cup of tea, broth or instant coffee too....
(big savings)
Repair manuals ($5)
http://www.panasonic.owner-manuals.com/NNS215MF-service-manual-PANASONIC.html
PANASONIC NN S215MF Service Manual
magnetron
https://www.amazon.com/s/ref=nb_sb_noss/158-8787537-8510360?url=search-alias%3Daps&field-keywords=nn-s215mf+magnetron&rh=i%3Aaps%2Ck%3Ann-s215mf+magnetron
Microwave pizza recipe
10 Best Microwave Pizza Recipes
Carnac the Magnificent
Mar 25, 2017 | Panasonic Microwave Ovens
MY EMERSON MW1119B STOPPED HEATING
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Jan 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
NN-SD297S The exhast fan still works but the oven
Due to the technology used in this model, there are no user serviceable parts inside. Call a Panasonic appliance engineer.
Mar 07, 2011 | Panasonic NNSD297SR 1200 Watts Microwave...
Starts and runs for 5 seconds and clicks off and shows no time on timer, back to ready mode, not the normal "enjoy your meal".
Starts and runs for 5 seconds and clicks off and Problem with the Panasonic NN-S963BF / NN-S963WF 1350 Watts Microwave Oven
Jan 31, 2011 | Panasonic NN-S963BF Microwave Oven
Buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Jun 21, 2009 | Panasonic NN-S433 1100 Watts Microwave...
Start but shut off after 5 seconds.panasonic microwave oven model NN-L531WF
Jul 04, 2008 | Panasonic Microwave Ovens
Panasonic NN-L531WF Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
