Question about Microwave Ovens
I need to replace the bulb on our Panasonic microwave, Model NN-H665/SN676. Apparently, the case must be opened. It looks as if this opening requires the use of a special "Torx-like" screw driver. Where can this be obtained or is there another way of changing the bulb?
  • 503 Answers
Please be careful,although it was an easy job, there is a capacitor inside which stores heavy loads of power and will release the electricity into you if you touch it!
YOU CANNOT REPLACE THE BULB FROM INSIDE THE MICROWAVE....... DO NOT REMOVE THE CARDBOARD-STYLE COVERING WHICH IS ATTACHED WITH ONE SCREW INSIDE THE MICROWAVE ON THE RIGHT.
To replace bulb will take 5 minutes.
UNPLUG microwave. Remove the outer cover by unscrewing about 6 screws (ordinary phillips) don't lose them into the workings.......
Bulb is located on the right side, nearer to the front. You cannot see the glass of the bulb, only the black plastic end piece, as the bulb sits upside down and vertically. Best if you check out what a T170 looks like on the internet, then you will know what you are looking for. For my Panasonic I needed a T170 (but be careful, they have different ends, some are straight, some right angled - mine was right angled - check before you buy and no, I don't think you can get them from any ordinary supermarket etc!!). Do not touch the bulb when replacing as the oil on your fingers will shorten its life.
Old bulb can be removed by taking out one screw and then pulling off the connectors - there is a little tab to push down to ease them off.
Then simply replace bulb!
When putting cover back on make sure all the tabs on top and sides go inside not outside casing.
Good luck. This is an easy job, just don't poke around anywhere else.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Oct 05, 2010
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: How can I obtain the
Many ovens are now built with "tamper-resistant" Torx screws. These have a center pin to keep a regular driver from fitting. You can buy drivers now at many stores or from online vendors. Sears has them, I think, and I know the Harbor Freight chain carries them if you have one near you. I just tried a search on eBay for "tamper torx" and there are a lot of vendors if you can't find them locally.
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
How does one replace the light bulb in the Panasonic NN-T990SA countertop microwave?
you have to remove the plug and then the outer casewhich is 4-5 screws on the back,you will find a air duct on the left hand side of the magnetron which is a metal box with two wires on the bottom.the bulb hosing is kept in with a screw and a metal tab,undo the screw and remove the two wires and that is the unit you have to replace,it is called a cap less bulb as it is one unit,reassembly is the reverse.hope this helps regards les
Nov 03, 2014 | Panasonic NN-T990SA Microwave Oven
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
There is a burning odour from the micro when its turned on.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | Panasonic NN-H665 1200 Watts Microwave...
How can I obtain the special Torx-like tool apparently required to remove the back of a Panasonic NN-H655/SN676 Inverter Microwave? I want to replace the light bulb.
Oct 05, 2010 | Panasonic NN-S768BA/WA Microwave Oven
Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
Jun 06, 2009 | Panasonic NN-T990SA Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic NN-ST666W Microwave oven
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed in most cases.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Panasonic parts in Australia here.
Dec 07, 2008 | Panasonic NN-P794SF Microwave Oven
Glass turntable
PANASONIC WILL SELL YOU THE PART ALL YOU NEED IS YOUR MODEL NUMBER
Dec 07, 2008 | Panasonic NN-H965 Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
