Question about La Crosse Radio-Controlled Digital Travel Alarm Clock
Ascot travel alarm clock - snooze does not work
3 Suggested Answers
  • 3 Answers
SOURCE: I have a Chaonei projection clock and the alarm
To turn off alarm1 press button named "up" and for alarm 2 press button "down" Note: No need to press mode or set anything you just need to press the above specified buttons directly when it is normally displaying the time
Posted on Apr 27, 2011
gopakumarg43
  • 74383 Answers
SOURCE: i am having trouble setting
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Posted on Aug 10, 2011
Setting the time on ascot projection alarm clock
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Mar 31, 2012 | Audio Players & Recorders
Have a bluehat time space projection alarm clock and the alarm won't turn off. Always goes to a snooze mode. Need help making it turn off. Instruction Manuel offers no help.
To turn off the alarm I pressed the alarm set button. While in the alarm set mode press the up button to turn the alarm and snooze off and on. That's what worked for us. Neat clock, the instructions are just a little lacking:)
Jan 19, 2012 | Toys
Nokia 1110 alarm click default snooze to off
when an alarm appears you have two options one is snooze other is off if you select off it wont snooze......... by default snooze will come after 10 mins even if you missed it first time you can off it next time ok.
Oct 21, 2011 | Nokia 1110 Cellular Phone
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
Jul 21, 2011 | Elgin Travel Alarm Clock
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Dec 24, 2009 | Eddie Bauer Watches
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
Nov 29, 2009 | Audio Players & Recorders
CAN U CHANGE THE SNOOZE TIME ON THE ALARM CLOCK AND HOW?
you go to your alarm settings in there you will find the option that snooze time in there you will change the time for snooze
Jun 11, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
How do I set the sleep timer?
To adjust snooze time - The system is set for a standard 10-minute snooze time (the number
of minutes you can delay the alarm). While the selected alarm is flashing, hold down Sleep⁄Snooze
and press the Time or to adjust the snooze time (from 1 to 30 minutes) for that alarm. The
number of minutes and Sn appear on the display to confirm your selected snooze time. You can
set a different snooze time for each alarm.
Oct 01, 2008 | Homedics SS-4000 Clock Radio
MOTO SLVR V6 SNOOZE TIME TOO SHORT
Well when you set the alarm there shud be an option to select how many minutes snooze is , so i suggest you reset the alarm clock and select your desired snooze time out .
Aug 15, 2007 | Motorola Mobility L6 Cellular Phone
La Crosse Radio-Controlled Digital Travel Alarm Clock Logo
352 people viewed this question
Top La Crosse Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
