Question about Panasonic Lumix DMC-FX36 Digital Camera
Have a DMC-LX3K camera and it takes great pix in the "dark" but most times I find that when set on Automatic the flash seems to overexpose pictures. Am I doing something wrong??
    Problem Solver:
  • 15 Answers
Nop! Nothing wrong. Try putting a white paper or a handkerchief to diffuse the light coming out of flash.
you are all set.
Posted on Oct 05, 2010
My flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
Jan 28, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
What is the best setting for indoor concerts? Alot of my pictures are blurry & either too dark or too light.
No flash, right? Concert pix are some of the hardest to do. 80% recovery is pretty good.
Don't use a speed slower than 60 (1/60th second).
try us use telephoto as much as possible, leaving the dark areas out of the picture. The camera metering gets confused when you have too much audience and other areas that are not lit up like the stage.
Other "experts" may have more "solutions" for you...
Sep 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
The flash on my Panasonic Lumix DMC-FX33 is not working. I did not drop it or anything, but suddenly every picture that should have a flash doesn't. The little screen shows that the flash should go off but...
You camera may be in 'auto'flash' mode, meaning the camera decides if the flash is necessary, depending on the lighting situatioin. Try your flash setting on forced flash instead of automatic, or try it in the dark to see if the flash goes off.
Jun 15, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Over exposure photos
Try change the exposure of the camera: start the camera, set the dial to 'I' (automatic iso), then press the 'up' menu near the display until 'exposure' settings appear. move the slider to the left/right, according to your preference.
I reccomend using the automatic iso for taking pictures, it automatically adjust exposure.
Apr 25, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Overexposure, Underexposure
Try this:
12-29-2007, 10:17 AM epuronen user_offline.gif vbmenu_register("postmenu_274670", true); Junior Member Join Date: Dec 2007 Posts: 1 icon1.gif Lumix TZ1 problem with flash I have experienced problems when using my Lumix TZ1 with flash. The pictures are often too dark but sometimes too light. I have now found a work-around for this problem. It consists of doing the following:
* set the sensitivity to ISO 100
* set the flash to "A"
* take a picture with the lens cap on
* remove the lense cap and take your pictures - they should come out fine
I don't know why this works but I think that when the TZ1 does not have enough information to compute a shot, it will rely on information from previous shots. Taking a picture with the lens cap on may reset the information in the camera so that it does not rely on previous shots. Setting the ISO to 100 will prevent the over exposed shots as the software may sometimes choose ISO 400
Dec 29, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
My camera is panasonic lumix dmc-fx 50
hello psdubbs, maybe you should reset the function parameters, they could have been changed.
Jun 25, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Pictures nearly black (overexposed )
Hi! It's weird that 1/2 of your photos were too dark. You didn't mention about the flash. Eventhough it is on auto mode, at night you still need to turn on the flash manually. Normally, it is a curve arrow pointing downward, you need to point your mode selector there. What brand of camera are you using though?
May 05, 2008 | Canon PowerShot A540 Digital Camera
Time for new flash??
the camera's light sensor or metering system, for correct flash exposure is no longer working, that's why your shots is either black or white (overexposed or underexposed) the flash firing has loose its control because of the defective sensor, it now only depends on the charge current of the flash capacitor. If you'll wait longer time the charge is maximum picture result will be overexposed(white), and vice versa, less charge, dark result, have the flash assy replaced. Daylight no problem, it doesnt use the flash circuitry, thanks
Jul 28, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Auto Settings Mode
Hello jmmarsh, replacement of the flash unit is the righ solution. 50 Euro for my account. If you need more info, please advice. Arpi
Mar 05, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Panasonic Lumix DMC-FX36 Digital Camera Logo
81 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
