Question about Lexmark X2500 All-In-One Printer
How do i find where to install the ink at? - Lexmark X2500 All-In-One Printer
  • 44 Answers
Scaner bed lifts up from the front and, you will see ink cartridges. Printer should be "on" when you lift scaner bed, so that ink cartridges move to the proper location for replacement.
Posted on Oct 05, 2010
Brother printermfc j430w will not accept ink cartriages i just install. screen says" no ink cartriages and install ink cartriage and ink black
Maybe are empty. You can manually check them. Take them out and look at them from the side that goes in the machine. There is a transparent plastic which if you are holding the crtridge exactly as it goes in the machine, it should have liquid ink inside. If its empty at that specific position is empty
Mar 21, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Installed new black and color cartridge.
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
Mp 160 don't work
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
WILL NOT PRINT!!!
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Lexmark X2500 All-In-One Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
